APX-7000 main display light
phillydjdan
Is there any way to turn the main display light off completely on an APX-7000? I can't find anything online about it. I have a feeling I can't turn it off, but I'm hoping someone has a magical keystroke that does it...
bobbynuts
Since you are discussing the main display, how ow about the intelligent lighting feature? Where do I find those setting in CPS?
hitechRadio
The intelligent lighting feature it is not changeable in the CPS it has to do with color change of the top display backlight and keypad backlighting, Green=Private Call and Paging. Orange=Emergency. Red=Out of Range, Battey Low and No Comms. The front display does not change backlight color, but LCD will show a colored box with the information of the alert in the colored area.
Ahhhhhh, Update! Here is a nice link that describes the Intelligent Lighting with Pictures too!
http://wiki.radioreference.com/index.php/APX_7000
bobbynuts
thanks for the clarification. I was under the impression that I could pick and choose the colors for alert purposes ( per channel or zones perhaps) , but I now see how they are used. The CPS does have a lot of help and tutorials, but couldn't find a quick answer on this.
mikegilbert
MHz so good
Los Angeles
I made a profile on mine called "battery saver" which has the same settings as my regular profile aside from the permanent backlight.
