Visar - No Rx/Tx after programming- Help needed
DesertCat
Hi,
I had purchased 2 used visar handsets on eBay with working Rx/Tx with only 2 channels programmed into them, I don't know the frequencies, but all you could do is navigate from 1 to 2 (2 channels).
I handed them to a local lab to program 6 Channels into them, lab succeeded to program 16 Channels...
The issue now is you can scroll between the channels but no Rx/Tx, Lab say it's faulty and do not have spare parts to fix it.
H05SDD9AA4DN - 16-Frequency, 2-Character Top Display, 4- to 1-Watt, 450 - 520MHz
H05SDH9AA7AN - 16-Frequency, 2-Character Top Display, 4- to 1-Watt, 450 - 520MHz, 3 x 4 Keypad
I suspect that there is something wrong with the programming, but I cannot tell without professional equipment.
Are there any basic test I can do having some kind of idea what is wrong?
Are these models repairable due of rear spare parts?
IAmSixNine
Dallas, TX
Do they BONK when you try to transmit? IF so they left the units as RX only.
Honestly with out knowing what they programmed or did to them its hard to tell if its hardware or software related.
DesertCat
Only short beep when you turn on
You can scroll between 16 programmed channels
No sound is heard when pressing the PTT
No red led on transmit or receive
SCPD
QRT
Virginia
Chit Chat
Reading the OP, sounds like the radios were talking before they got re-programmed.
If that's the case, you need to hand them right back, pretty plain they messed up programming new freqs into the radio.
Have them to put the original codeplug back in and see if the radios work.
This "local lab" didn't key up the radios and do a "hello radio hello test" back and forth before they gave back them to you? hmmm.
cmdrwill
So Cali
I hate it when some so-called "local lab" does that..
We ALWAYS check the radio after programming on the service monitor. Licensee's are required to have radios checked.
DesertCat
The "local Lab" here is very big they rent hundreds of radios to customers, but as I can see it they don't like to handle "old" devices, they rather sell new ones to customers.
I had returned the radios back for programming, and emphasize the fact they DID have Rx/Tx BEFORE it was programmed with 16 channels.
Since I had asked for the 446... range they said it's out of range and probably will not work, reading the batlabs, there is no issue with this kind of tiny "out-of-band".
More then that, I have more Visar with the same "out-of-band" working like charm, programmed by the same lab.
I wonder what happened this time.
BTY, on one of them while you press the PTT, the red LED is flashing rapidly, but no Rx/Tx.
