XTL CPS question
Hi Everyone,
Quick question, can you do the drag and drop thingy from the CPS going from a XTL5000 to dropping the programming into a XTL2500?
Thanks everyone!
-Ryan
Jeremylhunt
Asheboro, NC
Top Node drag and drop can be performed between two Xtl radios. There are some things to be aware of, if using trunking systems, make certain to load system keys in both cps code plugs that you are working with to insure that all data transfers across.
