I'm having trouble with my 4500. I recently had trouble talking into a repeater in an adjacent county. My transmission had come across as static. After being told i was unreadable, I used a different mobile and was able to talk into the same repeater just fine. After a little bit of think, I decided to check the output and found that the radio was only putting out a total of 5 watts. The strange part was that the radio was showing that it was in High Power.
Is this something that can be fixed using the radio itself or is this a problem that has to be fixed using the CPS?
Also, for information, the repeater used is an analog repeater and in the radio, the tones are correct and the transmit and receive frequencies are correct.
