MTR2000 repeat enable and disable with I/O
VE6VC
Calgary, Alberta
Does anyone have the programming and wiring info (for J5 connector) on how to enable and disable the repeat function using the I/O module on the MTR2000.
Thanks,
linboogy
Look at the GP110
i think thats a good starting point
VE6VC
Calgary, Alberta
I am hoping to ground a pin to knock down the repeat function and when the ground is released have the repeat function come back alive. I am using telemetry control from another control station.
Thanks,
a417
Very easy to do, although it has been some time since I've gotten my hands on an MTR2k. Just like linboogy said, start looking at GP_10 which correlates to pin C12 on the Systems Connector on the back. That pin allows WildCard Input (or WCI in the moto parlance for that system) and can control the unit as you see fit.
VE6VC
Calgary, Alberta
This is not doing what I want. I still want to RX by doing what was recommended it does not show a valid RX signal when you ground the pin that was chosen. In my case GPI9 as you are now adding a condition to the group. I want it to knock down the repeat function and not be a function of the group RX roles.
I will keep experimenting and hopefully I can get it to work. But so far no luck.
Thanks,
