Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 07-03-2016, 6:54 PM
Default Motorola Minitor VI 6 Amplifier Charger DIN Alerting Pinout ?
Does anyone have a definitive pinout for the Minitor 6 amplified charger DIN connector? Ive seen lots of varying and conflicting info on various forums and posts around the Net, mostly 5+ years old stuff so it may or may not apply to the new 6 model.
Im looking to setup an external relay to trip lights and a buzzer when the Minitor 6 goes off. Ive got the DIN cable, have the LED lights and buzzer, 12 volt power supply, will need to go get a relay but definitely need to have the correct triggers!
(12)CDM1550s (3)XPR4550s (5)XTS2500s (2)XTL2500s (2)EX560s BCD436HP BCD536HP IC-A110 VXA-220 And a whole lot more.....
Old 07-03-2016, 6:57 PM
SteveC0625's Avatar
The user guide for the V had the pinout info in it. If you've the charger amp for the VI, do you have the user guide for it?
Rochester-Monroe County 911 7010 1976 to 2003
Northampton Ambulance - Car 2829
KD2IAT --- WQPG808
Old 07-03-2016, 7:09 PM
SteveC0625's Avatar
Better yet, I found the manual online. Here's a link to it: https://drive.google.com/file/d/0B3k...ew?usp=sharing
Accessory connector info and pin outs start on page 7.
KD2IAT --- WQPG808
Old 07-03-2016, 7:49 PM
How the hell.... Ive been searching hours for that online over the course of several different attempts, and Im a google master! Haha - thanks!
Old 07-03-2016, 7:51 PM
For everyone in the future in case that PDF disappears...
Old 07-03-2016, 8:44 PM
SteveC0625's Avatar
It, pager user guide, and basic service manual all in the first place I looked: MOL.
KD2IAT --- WQPG808
Old 07-03-2016, 10:26 PM
Thanks again! Maybe you or someone else can help with wiring now. I thought I had it, but maybe not.
Ive got a single flashing LED light right now Im testing with, a 110v wall power supply to 12v .75amp, and the Minitor 6 amplified charger.
Power supply plugged into the wall, ground connected to ground of the LED light. Positive from the power supply connected to Pin 2 dry contact, and then Pin 3 dry contact connected to the positive for the LED light. Tones should drop, trip the relay and pass that power through to power the LED Light, correct? I plan to do a relay setup for the full system but im just testing right now to get the correct wiring down.
Thanks!
Old 07-05-2016, 12:49 AM
Anyone? I will draw up a diagram in the morning if it helps. Thanks!
Old 08-04-2016, 3:28 PM
Thanks!
This does seem correct yes. Did you ever give it a try?
Old 09-11-2016, 6:29 PM
Yes I tried that - couldnt get the external LED I had hooked up to light or any indication anything was happening. Hoping someone here had a working alert system that could explain how theyve got it setup! Thank you!
Old 01-15-2017, 7:40 PM
Bumping this up hoping to get more eyes on it, would like to revisit this project this week. Ive got a Min 6 amp charger and the DIN plug cable but have no idea what to do from here - tried one diagram I found but nothing worked. Help!!
Old 03-30-2018, 1:36 PM
I know this is a year old, but figured it could help someone. I'm still looking for good information on a 5 pin cable with a ground that conducts and is not just a shield.
