d_strong
Re: text justification
I have a Motorola XTS-5000 model II programming with Astro 25 portable CPS R20.01.00. The problem that I'm having is the channel display is set to the left. I'm trying to set to the right with negative results. I don't know if you have to unlock another field to edit this field. I'm getting error message when trying to put an channel higher than 9 ? Thanks.
