APX 8000 Call ID
rustyjw
How do you program a Call ID number for a contact name in the MDC Conventional Hot List? I have programmed 1250s in the past and there is a way to have radio A with an ID of 1234 and have radio B display it as CHIEF. I'm trying to do the same thing on the APX8000. How do I do that?
racer38
N Oxford, MA
As stated unified call list entry, then add it to the MDC Hot List and it will work . See attached screen captures. Took me a while to figure it out as it wasn't as easy as the older software.
sfd119
I think you only need it in the Unified Contact List, no need to add it to the hot list.
racer38
N Oxford, MA
That could be, I'll have to check it. I know to add it to the MDC Hotlist it has to be in the Unified List. I am using the MDC Hotlist as I am adding additional lists for my HAM P25 stuff since everyone is using CCS7 numbers.
sfd119
I just double checked my code plug. Unified Call list is all you need. No need for MDC or Astro Hot Lists.
rustyjw
What is the Primary ID field for? It does not seem customizable.
