Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 10-17-2016, 10:55 PM
Default R1225 Channel Display shows FF
While making a few changes to my R1225 Repeater using the RSS software my display changed to FF on the radio when I wrote the changes to it.
Now I cannot get the radio to display channel numbers!!!!
Could it be a code plug issue?
Any help would be appreciated.
Old 10-17-2016, 11:19 PM
mmckenna's Avatar
Slightly different model, but give this a try:
http://www.repeater-builder.com/motorola/sm50/sm50.html
"SM120 Displays "FF":
After a programming session, the radio displays "FF" and it won't transmit at all. Cycling the power or rewriting the code plug doesn't fix a thing.
Apparently the "FF" indicates the radio did not exit programming mode properly. If you hold the '+' and '-' keys at the same time for three seconds, this seems to cause the radio to exit programming mode."
"I cut it three times and it's still too short!"
Old 10-18-2016, 12:12 AM
Default R1225 FF in display
The keys on the 1225 are up and down arrows. I hit both and it did not clear the FF.
Old 06-19-2017, 1:53 AM
Did anything work for you? I am having a similar problem on my GR1225.
Old 06-19-2017, 11:30 AM
mr762443,
sounds like a code plug problem. If you have a good known working code plug try to clone it back into that radio.
Old 06-19-2017, 3:40 PM
cmdrwill's Avatar
You DID Save the original 'code plug'. You ALWAYS READ the radio first, save a copy of the cp, THEN make changes.
