Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 10-20-2016, 10:50 PM
Priority-One's Avatar
Default XTS5000 advanced keys
I just purchased a VHF XTS5000 and spent about 3 hours programming it tonight.
I went to write the radio with all the AAR channels on RX only and I keep getting the message below
What can I do to fix this problem? as I DO NOT WANT TRUNKING
I'm looking to use this radio for P25 and Conventional RX only
Providing the broadcastify feed for the 25/28/32 pcts in Harlem.
Old 10-21-2016, 12:06 AM
BigLebowski's Avatar
You either need the advanced system key(s) for the systems that were programmed into the radio or you will need to hex edit the codeplug for the radio to remove the ASK requirement. Instructions for this are floating around on the internet.
Old 10-21-2016, 12:10 AM
I may be willing to pay someone to help me out for the right price. I just want to be able to program conventional analog and conventional P25 vhf. No trunking
Old 10-21-2016, 12:19 AM
This is the ASK problem, which is by far one of the STUPIDEST things Motorola ever did, in some ways it's even more stupid than when they "toolproofed" the Jedi radios to keep leaked lab software from being used with them.
With the ASK problem, Advanced System Key enabled, if you don't have the relevant Advanced System Keys in your programming computer, you can't edit the radio's contents and be able to save them to the radio, even if you only edit conventional data. Even if there's no trunking data in the radio, the presence of the ASK demands that the keys have to be in your programming computer for the trunked system(s) that used the ASK in question.
What this means is that radios can NOT have their trunking data removed from them unless they're removed from a computer that has the valid ASK keys loaded into it.
Which is precisely the OPPOSITE of what a system administrator should want to happen, from the perspective of system security.
Imagine...a bunch of radios get sent to public auction because they're out of date. But they still have the trunked system data in them and can still interact with the system....but they can't be deprogrammed!
Really, it IS that stupid.
Yes, there are ways to remove the ASK from the radio. I know of at least two. Neither of which I'm going to talk about and neither of which I can provide to anybody for any reason.
No, I will not program your radio for you. No, I will not give you any software. Don't ask unless you want a rude answer.
Old 10-21-2016, 12:24 AM
This is exactly what has happened to me. I got the radio last week in an auction, spent hours today on my day off programming it, only to find it's worthless now and I can not return it per the policy of the seller.
So what am I to do now with the radio?
It's programmed with some military VHF trunked system for which I have no use for.
I am looking for an option to remediate this problem so I can program the radio for RX only.
I'd be willing to pay someone to help remove the ASK. I don't want anything to do with the TRS. just the conventional P25 and analog programming.
Old 10-21-2016, 1:01 AM
ASK ouch
Old 10-21-2016, 2:11 AM
I fixed it! Thanks for all the help!
Old 10-21-2016, 2:13 AM
RayAir's Avatar
Pretty sure there was an ASK removal tool.
Not sure you'll find it here. Try that Australian site.
KXKYC JBSOB XBMZE LCVHV WCW
Old 10-21-2016, 2:15 AM
I used the tool and rewrote the code plug with some great advice from a friend. So it's all good now and I wrote it with the AAR RX only channels. Works great
Old 10-21-2016, 10:01 AM
There is an actual tool to remove the ASK? I have an MCS2000 that was programmed with a ASK and it's just collecting dust in my garage.
Old 11-02-2016, 9:34 AM
K5KDF's Avatar
reflash the radio will remove the ASK
I use a radio not a scanner
Old 01-12-2018, 11:46 PM
I have a xts 2500 that I got for work and I went to take it to the radio shop for programming and it has ASK on it. I need help getting it removed. The radio shop said they are busy so I have to remove it then they will program it. I need help please.
Old 01-13-2018, 6:49 PM
captaincab's Avatar
Location: monitoring delco pa with gre psr300 pro2053 and bearcat 560xlt
Hmmmm seems weird a radio shop turning down a customer for a job like that.
Old 01-13-2018, 6:50 PM
Hey. Sorry for the delay. You have to have depot software for Astro radios to blow out the ASK.
Old 01-13-2018, 7:43 PM
MCore25's Avatar
Not if it’s a radio shop directly attached to the system being used. Example, most large municipalities and large state agencies have their own in-house radio techs. Some systems are so strict that even MR’s can’t obtain the clone key let alone an ASK. Also forces all programming jobs to go through the municipality’s radio shop.
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you…
Old 01-14-2018, 10:30 AM
clbsquared's Avatar
PM me, Rescue. I can help.
