Have a xts5000 with latest firmware and dsp when i try to read radio i get a context 24 c000039e i am using the latest software to
Sent from my LG-D321 using Tapatalk
Some people confuse the software. For example, the XTS3000 software will NOT program the XTS5000 yet, numerous users have tried.
The proper software is Astro25 CPS for portable, and I think the latest revision is R20.01.00? Also, you will need a programming cable that is compatible with the XTS5000; the cable being another issue as some users think a single cable will work across the entire family of radios.
Finally, even if you do have the correct software and the correct cable, the software must be the same revision, or newer, than the software last used to program the radio. Therefore, if your CPS is older than the software last used to program the radio with, it will not work.
Check those things out and ensure it all adds up, and see if that troubleshoots the issue.
Paul
