Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
  #41 (permalink)
Old 11-09-2017, 3:22 PM
rescue161's Avatar
KE4FHH
Yes, the AN only affected the 2500 as the AN 2500 only had 4MB of space. The BN 2500 was upgraded to 8MB. The 5000 has 8MB on the AN.
Hams Against Magnetic Mounts
  #42 (permalink)
Old 11-10-2017, 2:31 PM
Signal-Zero's Avatar
Originally Posted by MCore25 View Post
Motorola: Motorola Proprietary Features is checked and Validate NAC Agianst System ID is also checked.
Harris: Uncheck the above, check WUID Validity Support
My personal APX6000 is non-affiliate scanning a Harris system just fine using the “Motorola” checks above just fine. Not missing a beat. As far as actually TXing on the system, you may have to set it up as MCore25 stated, but for non-affiliate scanning it’s not required.
I had an issue with a Harris system only passing half the audio on an XTL5000. I changed the WACN to the Motorola default of BEE00 instead of the actual WACN and it worked ! This was a UHF P25 system and my firmware was 20.50.05.
"We celebrate our independence from the Government, not our dependence on it."
  #43 (permalink)
Old 11-21-2017, 7:00 AM
Also tried MCore25’s recommended Harris settings and it also receives fine using an APX6000. I don’t see why this shouldn’t work with a XTS/XTL but I haven’t tried it.
  #44 (permalink)
Old 02-12-2018, 3:52 PM
where do i find the validate nac against system id. i dont see that option only the wuid support and moto prop. features. using cps r20.01
  #45 (permalink)
Old 02-13-2018, 8:44 AM
Location: New York North Carolina and all points in between
Quote"
I believe that's for APX radios. You first problem based upon the firmware version you posted is that it doesn't have the ignore Voice Channel NAC. You need 20.50.5 as a minimum firmware that Mot made to correct this issue, and allow Mot radios on non Mot systems.
  #46 (permalink)
Old 02-13-2018, 8:52 AM
my bad i failed to mention i now have a radio with firmware 20.50.09.
and i was under the impression the validate nac was also for the xts.
  #47 (permalink)
Old 02-13-2018, 9:48 AM
Well I wish you luck I am still having problems with trying to monitor my system
  #48 (permalink)
Old 02-13-2018, 10:28 AM
davidzimmerman's Avatar
i use to use a Motorola XTS2500 on a P25 Harris System for Non-Affiliation Scanning worked GREAT no problems then i sold my radio and got the G5 VHF pager that also works great and do not have to worry on making system keys for each system.
