Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 06-19-2017, 7:39 AM
Default Astro saber
Good morning
I have an Astro saber portable, after keying up to talk and release ptt I get the low battery signal without low battery icon . I am using brand new batteries. Anyone have ideas on what the problem is and how to correct it ?
Thanks in advance
Old 06-19-2017, 7:42 AM
Are they OEM, or after-market batteries? I had a Honeywell battery back in the day that would always beep low-battery. It didn't provide the proper voltage, though the capacity was just fine.
Old 06-19-2017, 9:28 AM
thanks , they are aftermarket 2700 mha batteries. I will see if I can find oem batteries
Old 06-19-2017, 9:31 AM
+1 on the above answer. I had this issue with a non OEM battery bought off of an online auction site. I needed a physically smaller battery for use in an XTVA adapter.
There must be a batch of batteries out there like this.
These are great radios though, so it is worth it to have battery cells replaced or rebuilt when they fail.
Old 06-19-2017, 11:52 AM
I had a similar problem years ago with W&W batteries. I have used many aftermarket batteries, & they all worked well, but the W&W were absolute junk. What brand are they?
FORMERLY MOONBOOTS
Old 06-19-2017, 11:54 AM
MCore25's Avatar
Except for one radio (which is in an AVA) all of my Astro Sabers run the Li-on batteries from Power Products.
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you
Old 06-19-2017, 12:46 PM
62Truck's Avatar
I had a Power Products short Lion, and I had nothing but problems with those batteries. The Honeywell's seem to work pretty good.
Lions, Tigers, Bears....
Old 06-19-2017, 1:39 PM
marcotor's Avatar
I have always had good success buying Li-ion from Cutrate batteries, and in particular use These.
(use the dropdown to select the 1950mA Li-Ion)
$76 shipped and makes my AS as manageable/pocketable as any of my XTS radios.
Impressive Scanner/Radio list:
Old 06-19-2017, 4:04 PM
MCore25's Avatar
I've got 7 of them...not one issue.
Old 06-20-2017, 1:16 AM
RFI-EMI-GUY's Avatar
What chargers work with those batteries?
"Have Spectrum Analyzer, - Will travel" "Going Green"
Old 06-20-2017, 1:18 AM
Has anyone used those cheap 5000 mAh Li-ions from ebay? Any good? Dimensions?
Old 06-20-2017, 5:03 AM
Motorola Tri Chem. NTN8831.
FORMERLY MOONBOOTS
Old 06-20-2017, 3:24 PM
marcotor's Avatar
I haven't had any problems using them in my IMPRES WLPN4114's
Old 06-20-2017, 10:12 PM
gtaman's Avatar
Use the Multiplier brand. Very good batteries.
My RT-1523E SINCGARS is just an oversized armored Motorola Maxtrac.
Old 06-20-2017, 10:32 PM
any particular SW version I should look for? Does this require an insert for any of the batteries?
Old 06-20-2017, 11:13 PM
A charger's FW really only counts in Impres chargers. 3.4, or greater. 3.11 is the most recent.
FORMERLY MOONBOOTS
