Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 09-12-2017, 7:04 PM
Default Motorola 7500 Dispatch console
Is there a way to run to mics in one console. Our department is in the unfortunate process of handing off Dispatch operations to the PD. Right now if the PD dispatcher wants to talk to a fire unit he has to either change the select radio or use the touch screen to talk on the unselected channel. Is there a way to have two selected channels with two separate mics?
Old 09-12-2017, 8:55 PM
MCore25's Avatar
That pretty much goes against all console logic…I'd say use the backup radio at the position as the I selected transmit.
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you…
Old 09-13-2017, 8:09 PM
What's the issue with talking on an unselected channel? I do it quite a bit. Otherwise you click on it and make it selected....
Old 09-13-2017, 9:25 PM
crazyboy's Avatar
Time for new dispatchers if they can't manage this.
Old 09-16-2017, 11:33 PM
Yeah they gotta just instant-transmit or change select. Instant transmit is the recommended method. There is no method in MCC7500 to have 2 select channels.
Semper Audire
I copy your 73s. Prepare to copy 9-Line, over.
Old 09-19-2017, 11:19 AM
KK4NEF's Avatar
Or better training, although it is not a difficult task.
Austin Jewsbury KK4NEF
Motorola APX-8000/Yaesu FT-857D/Kenwood TR-7930/Harris 700p/SDRPlay/XTL-5000/Yaesu-3200d/Motorola HT-1250/TYT-MD380/XTL-2500/UV-3R MKII/Harris 7100ip/Motorola XPR-3500
