Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 10-06-2017, 12:11 PM
800trashman's Avatar
Default Motorola Astro Spectra Railroad
I have searched extensively, and found nada, please forgive me if I am searching the wrong thing. I have a Astro Spectra RR radio, and looking to use it indoors via the 13.8, with a Astron power unit. As you know these units have the 72v plug on the unit. I am not good at wiring at all, and looking to see if there is a converter that is made somewhere that will allow me to plug into that plug on the radio and connect to my Astron power unit? Any help is much appreciated!
Old 10-06-2017, 1:19 PM
The connector is four pin...two are used for 70 VDC and the other two are for 12v.
Old 10-06-2017, 1:22 PM
Google the pin out and get the polarity correct the first time. Don't blow up an irreplaceble radio.
Making your scanner useless, county by county.
Encryption, it pays my mortgage.
Old 10-06-2017, 1:59 PM
Exactly!, That is why I was looking for a pre-made unit, that I could not screw up!! I have this from Batlabs, but is greek to me...
(The pinouts of the connectors on the radio go like this:
Power connector:
A --- +72 volts
B --- -13.8 volts
C --- - 72 volts
D --- +13.8 volts
Use only A and C for railroad 72 volt (nominal 64V supply) power, or B and D for 13.8 volt (nominal 12V supply). The 72 volt supply floats; the 13.8 volt supply is negative ground.)
Is there a connector sold somewhere that would let me just plug into the wall - or my power unit?
Old 10-06-2017, 3:51 PM
That connector is a pretty standard Amphenol/Cannon style connector. You can get them from Mouser or Newark electronics. The Motorola manual (if you can find one) may have a parts breakdown showing the manufacturer part number. Batlabs is a good resource and if you do not have the rear connector, someone there may be able to offer you a resolution.
The rear connector (if you have it) will have the pin numbers somewhere on the housing, and you can de-pin the connector and swap the wires to the correct pins.
Old 10-06-2017, 4:41 PM
So if B is my negative, and D is my positive on the 13.8, any reason why I cant use the Red and Black wires from my Astron power unit and somehow couple them with the Amphenol/Cannon style connector and get power that way?
Old 10-06-2017, 4:52 PM
No problem at all. I would try to source that connector, it makes it a LOT easier.
Old 10-06-2017, 4:53 PM
Remember that Railroad Spectra are FLOATING GROUND. Make sure you wire both the positive and negative leads to the connector and not chassis.
Old 10-06-2017, 4:55 PM
Batlabs was a source for the power connector, read their site.
Old 10-06-2017, 7:24 PM
Whether you use 70vdc or 12vdc, both are filtered and sent through a DC DC converter for isolation. It's the radio that's grounded, not the power source.
Old 10-07-2017, 4:26 AM
So if I use my Astron power unit (thus giving me an on off switch), add the Amphenol connector with B & D ports connected to red and black , and not worry about adding a ground wire?
Old 10-12-2017, 7:46 AM
Can anyone advise what the antenna connector is on the Astro Spectra RR radio? Is it the standard mini uhf? Thanks
Old 10-12-2017, 3:54 PM
It is a standard PL-259 connector for the antenna.
Regards,
-Frank C.
Old 10-12-2017, 4:41 PM
No it's not. Every Motorola mobile radio from the Maxtrac line going forward uses a MINI UHF connector.
Which I hate...but at least it fits through a small hole.
Does this look like a PL-259 to ANYBODY?
No, I will not program your radio for you. No, I will not give you any software. Don't ask unless you want a rude answer.
Old 10-12-2017, 6:50 PM
Originally Posted by ElroyJetson View Post
Which I hate...
You're not alone. But it does generate a lot of service calls for radio issues only to find a loose mini UHF..
I would much rather see them use something like a TNC like GE used on some of their radios. At least it has a gasket to tighten against and is much less subject to loosening.
It looks like a F connector. I have ran across many F connectors threaded on a spectra and the like. Threaded on with a pair of pliers of course.
Old 10-12-2017, 8:11 PM
mancow's Avatar
It's a mini-uhf.
Old 10-12-2017, 8:13 PM
The railroad version, if it's the clean-cab model will have a standard PL259 connection, but from what it sounds like, the original poster does not have the actual radio in their possession.
Old 10-12-2017, 8:50 PM
Originally Posted by mancow View Post
It's a mini-uhf.
Yes, I am well aware. My comment was pure sarcasm given what I have seen done in the communications industry.
Old 10-13-2017, 9:46 AM
This looks like a mini uhf to me, no?
Old 10-13-2017, 10:26 AM
That my friend is what many people call an SO-239. It's the female connector that mates with a PL-259. You use a standard PL-259 connector on it.
Jim
