Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
  #41 (permalink)
Old 10-14-2017, 2:16 PM
nope. so being partially phase 2 would cause me to hear some bit not all traffic?
  #42 (permalink)
Old 10-14-2017, 2:17 PM
clbsquared's Avatar
Bingo.
Sent from my HTC One A9 using Tapatalk
  #43 (permalink)
Old 10-14-2017, 2:19 PM
damm. Who has an APX for sale
  #44 (permalink)
Old 10-14-2017, 5:25 PM
Originally Posted by MedicDavid78 View Post
setting Coverage Type to SmartZone causes the radio to constantly search for a tower Site
Nonsense.
  #45 (permalink)
Old 10-14-2017, 6:03 PM
equalizer245's Avatar
Exactly
Sent from my LG-H343 using Tapatalk
  #46 (permalink)
Old 10-14-2017, 6:09 PM
Only way I've seen it try to affiliate as if I manually put the radio on a trucking talk group that's why your channel selector becomes your Zone selector so you can't do that and if you hit the push to talk button the way to scan list is setup it's set for fixed so when I try to transmit it's always going to go back to the conventional Channel which I have to receive inhibited on it makes sense
  #47 (permalink)
Old 10-15-2017, 9:04 AM
911ert's Avatar
Iím betting that they have encryption turned on.
  #48 (permalink)
Old 10-15-2017, 12:20 PM
Who knows my experience my County just switch to the p25 9600 before that we was on a mix mode and most of my County was on analog and I was having trouble picking up the new system talk groups it was mentioned to me that my radio probably needed to be relined my XTS 1500 was 128 kilohertz off frequency and 5000 was close to 100 after I sent them off to get aligned I rarely miss a call unless I'm on one of those single sites my county is a simulcast but they have individual sites on the county Edge I'm assuming for overlap to fill-in the dead spots I've noticed if I got the radio in a certain spot even though I'm picking up the control Channel good the voice Channel might not be so good in my experience I just moved the radio and then start here in traffic that happened on analog also you get a voice channel is coming in good in the next one might be a little fuzzy I'm thinking that might be what kind of problem he's having if it was me I'd go up close to one of those sites I see if I still have the same issue
  #49 (permalink)
Old 10-15-2017, 5:35 PM
RKG's Avatar
RKG RKG is online now
Selecting SmartZone will always force affiliation if the channel containing the talkgroup is selected using the channel selector. Whether it does the same thing when the radio has scan stopped on a non-priority scan list channel that is not selected is something I do not know.
On the other hand, if selecting SmartZone does not cause an affiliation on a non-selected scan list landing, then it will do nothing for you. What SmartZone activation does (in addition to sending periodic affiliation messages) is to cause the radio to evaluate received signal strength of the control channel, compare that to a table of acceptable values programming into your radio to see if the radio should remain on that site, and, if not, causing the radio to sample the list of adjacent site control channel frequencies that are periodically broadcast by the control channel beacon.
  #50 (permalink)
Old 10-15-2017, 6:08 PM
rescue161's Avatar
KE4FHH
The radio will not attempt to affiliate if you are on a conventional channel and scan a SmartZone talkgroup, unless you have the scan list set for Talkback and bump the PTT. Then it will attempt to affiliate, even if you have TG/AG Disabled checked. TG/AG Disabled does nothing to stop the radio from affiliating.
In the end, if you see the red LED blink, you've done something wrong and you should go back and read more.
Hams Against Magnetic Mounts
  #51 (permalink)
Old 10-15-2017, 10:35 PM
The very nature of SmartZone is to tell the system central controller to direct the talkgroup you're on to be sent to the site you're on. If you roam out of your normal coverage area (say you're listening to the north site's tac 1 channel and have to go to the south site's coverage area) then the talkgroup you've selected will follow you.
That's how smartzone works and of course it demands that the radio affiliate with the site. So that's a primary reason why the right way to scan has you NEVER directly selecting a trunked talkgroup. That's why I say to park all your talkgroups out of range of the channel selector knob's range. Set up, for example, a zone with 32 channels in it and conventional channels are on the first 16 positions and you put the trunking talkgroups on positions 17 thru 32. As long as you don't also program up a CHAN or SUB menu into the radio, you will then not be able to directly select the trunked groups.
No, I will not program your radio for you. No, I will not give you any software. Don't ask unless you want a rude answer.
  #52 (permalink)
Old 10-15-2017, 11:03 PM
I have also found that setting the TX offset to 0 instead of - 45 eliminates any chance of affiliating
  #53 (permalink)
Old 10-16-2017, 3:27 PM
The only issues I believe is on just one talk group, that is my city police. The county sheriff talk-group seems to work fine and Iím not missing traffic , i believe it is because maybe county sheriff is monitored by the highway patrol which is on a P25 phase 1 so all of the county sheriff is on phase 1 while the city police is on a combination pf phase 1 and 2. Unless something else is up thats making me loose traffic.
