No busy LED
ozzie
mn.
I have no busy LED on signal reception. The LED will illuminate on power up but not on reception of a signal, so I know its not burned out. The busy LED box is checked under conv personalities. Thanks
Model--M2URM9PW1AN
Flashcode--5892A8-F01E84-9
box23
State of Superior
Model--M2URM9PW1AN
Judging by the extensive flashcode in your 7/800MHz XTL2500 and your question, I'm going to assume you're using non-affiliate scan techniques.
That being the case, even though the radio is scanning from a conventional personality it is not receiving through that personality, so the checkbox you referenced is not applicable. Therefore you do not see the Rx indicator light as ASTRO25 radios do not utilize the light in normal trunking operation.
ozzie
mn.
I was using a different radio prior with a much less extensive flashcode and the busy light would come on. This flashcode may be way overkill for a non affiliate scan.
