Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 02-13-2018, 9:56 AM
JMR3865's Avatar
Default APX HELP
Hi All,
A couple questions on the APX series. I'm looking to use it more as a receiver.
Can the APX
Monitor a phase 2 talkgroup/trunked system without being on the system
Scan multiple trunked systems
Scan trunked systems and conventional channels?
Thanks for the info!
JMR
Old 02-13-2018, 9:59 AM
Mr_Boh's Avatar
Yes on all. The last one there are some caveats about conventional and trunked at the same time. I havenít done too much since I typically just scan multiple trunked systems but for trunked and conventional I think the Scan Lists canít be blended but you can scan a Conventional list while parked on a talkgroup and scan talkgroup list while on conventional like the Astro 25 series stuff. Iím sure someone will correct me though.
Old 02-13-2018, 10:14 AM
JMR3865's Avatar
How does one program the radio so thatf it will not try and affiliate with the trunked system
Sent from my SM-G950U using Tapatalk
JMR
Old 02-13-2018, 10:26 AM
davidzimmerman's Avatar
Originally Posted by JMR3865 View Post
You just Open a can or WORMS on asking how to program it like a scanner PAY someone to do it for you who KNOWS how do it. Don't try it by your self or your radio will get bricked.
Old 02-19-2018, 6:01 AM
JMR3865's Avatar
I'm not new to programming. I have been programming for over 15 years, however, I have never programmed a trunking radio nor the APX's.
I was simply asking if there was a way. If someone could explain how, that would be superb! I am not against someone else programming it to ensure that it is done correctly.
JMR
Old 02-19-2018, 6:18 AM
Mr_Boh's Avatar
Iím going to sound a bit nasty saying this but Iíll say it anyway - itís well documented here and other sources. No need to start yet another thread on it.
Phase II just adds another minor layer to the programming. If you can follow the steps for a Phase I system and understand what each setting means and why itís set the way it is, you should have no problem doing a Phase II.
Old 02-19-2018, 6:28 AM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
The problem is to properly program an APX radio to "No Affiliate Monitor" requires
one to create a bogus System Key which can be (depending on local laws) illegal or or at the very least frowned upon. It is akin to creating a key for a house door lock for a house you don't own and have not been given permission to enter.
Marshall KE4ZNR
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
Old 02-19-2018, 8:05 AM
Except to create a house key for a house you do not own, you would have to steal the original house key, & take it to Home Depot, or anyplace that has a key machine, copy it, & return the original key. With the radio, you simply go on the computer to a key generating site, & generate a key without stealing anything.
FORMERLY MOONBOOTS
Old 02-19-2018, 8:22 AM
JMR3865's Avatar
Thanks everyone!
JMR
Old 02-19-2018, 10:43 AM
KE4ZNR's Avatar
Except that in some areas generating a key is either illegal and/or frowned upon by those responsible for maintaining said radio system. That is kind of the whole purpose of System Keys: to keep those that should not have access to the system from the system. Granted, Motorola has giant flaws in how this is implemented but that still does not make generating a system key without the system administrators permission ok.
Marshall KE4ZNR
@KE4ZNR on Twitter
Old 02-19-2018, 10:56 AM
Originally Posted by KE4ZNR View Post
but that still does not make generating a system key without the system administrators permission OK
In life, there are many choices, & many shades of gray. In my life, there is only 1 question I ask whenever I do something. "Will I go to jail if I do this"? If the answer is yes, then I don't do it. It's not like going to a key generating site will have the same consequences as going to a kiddy porn site.
FORMERLY MOONBOOTS
Old 02-19-2018, 10:35 PM
kingpin's Avatar
Trailer Park Supervisor
Cool Bricked
And I don't mind telling you as a system administrator, I will brick your radio if it doesn't belong on my system . Been there, done that. Someone has some expensive paperweights.
Stay off of systems where you don't belong, and you won't have trouble.
Jason - W4IRQ
AL Database Admin - Radioreference.com
www.radiokingpin.com
Group Owner - South Alabama Scan
http://groups.yahoo.com/group/southalabamascan/
Old 02-20-2018, 12:19 AM
Depot Software will fix this problem
Old 02-20-2018, 6:03 AM
JMR3865's Avatar
Just to clarify...
I am a FF/EMT. I have permission to use our VHF system. I MAY have the ability to use our trunked system that is coming our way. I am NOT looking to transmit on anything that I shouldn't be. I just want to listen to the trunked system with a radio, not a scanner.
JMR
Old 02-20-2018, 7:07 AM
sure don't think the system administrator can care less what and who you are lol have someone who KNOWS how to program the radio or have the police at your front door.
Old 02-20-2018, 9:12 AM
Location: New York North Carolina and all points in between
I think the best response is "If you don't know how to make your radio do NAS, then don't do it". There are plenty of sites out there for information, and this one doesn't like said information posted here. At most of the others they will not program your radio or hand hold you, so do some research, and learn.
Old 02-20-2018, 9:27 AM
Just to clarify...
Then have the person who gave you permission program your radio.
FORMERLY MOONBOOTS
Old 02-22-2018, 2:54 PM
kingpin's Avatar
True, but you shouldn't have it unless you are authorized.
Forcing a radio onto a public safety trunked system you are not authorized for, is asking for trouble. It is a felony in the state of Alabama for example. It's not worth it.
Jason - W4IRQ
Old 02-22-2018, 3:14 PM
But how did it ever get out of the factory in the first place? I've seen it for sale on E-Bay from time to time. Moto only has themselves to blame that it's out there.
FORMERLY MOONBOOTS
Old 02-22-2018, 3:45 PM
Sent you a PM.
