Motorola XTS3000 Codeplug Help
mw1coe
Gas, KS
Just Purchased a XTS3000 V2 450-520 Radio For Ham Radio Use Only
I performed an Out of Band mod to allow the 440 frequencies to be loaded..
I bought this radio and It was not reset by the Seller meaning that it had Settings stored for the DC Police on it..
Im trying to use this on a MMDVM Ham Radio Module and only need Low Power..
Does anyone happen to have a Codeplug compatible with this Unit I can have Please ?
Rob..
H09SDF9PW7BN
500004-000000-5
R05.03.00
toolman60
What settings stored that you can not change in CPS? As I am thinking about getting a XTS and do not want them kind of problems.
mw1coe
Gas, KS
Im Guessing its just me..
Maybe I didn't set something correct so I'm looking for a Template to make sure..
Right now I can receive a signal but not transmit so I'm definitely leaning towards driver error aka ME..
Need to find a definitive guide then I can make a code plug that works with this unit straight off the Bat..
toolman60
If you like me to look at your setup I be glad to. If you are rx the correct freq. I would say it is something you missed in CPS programming.
mw1coe
Gas, KS
Yeah pretty much bet the farm its jacked up..
Just added some contacts as per a website and it dont work right..
Prob be better off with a new csv file I can upload..
But if you wanna take a look sure..
toolman60
If the radio has not been whored out the original code plug should work fine for reprogramming for amateur use. I have not had any problems programming my AS or HT1250's.
I will take a look at it if you want to send it to me at toolmansixtyunderscorenintynineayahoodotcom. Just replace the written text for the numbers to actual numbers.
mm
oregon
As FFPM571 says It sure sounds like an unfamiliarity issue with cps.
I had 5 xts3000 model 3's over the last 15 years. Each one began life in the 450-512 band and I converted and used each to the 439-450 ham band and I never had and issue with any tx or rx frequency.
I also use them for RX up to 470 MHz with no issues.
I_am_Alpha1
Welcome to RR.
Don't give up...it can be done. You've learned two important points already. 1. CPS is nothing like Chirp or RT Systems software. 2. RR is not always a friendly place...lots of people that post just to feel important by putting down others. You've accomplished two major hurdles so far...software is running and radio is unlocked. Radios sold on E-Bay, for the most part, are locked. Unlocking an XTS5000 is simple...the XTS3000 can be tricky unless you are comfortable with HEX editing and Depot software.
Rule #1...always save your codeplug and never mess with it--use a copy. Rule #2...Every time you want to change the programming, read the radio and see Rule #1.
Post your codeplug to dropbox or some other place I can download it. I don't have a 3K codeplug to open and guide you. The CPS has a plethera of settings and it's very easy to miss a checkbox or dropdown menu.
cmdrwill
So Cali
Rule #1...always save your codeplug and never mess with it--use a copy. Rule #2...Every time you want to change the programming, read the radio and see Rule #1. .
Exactly, and the original 'codeplug' IS stored in a separate archive.
Never jam a 'codeplug' in a radio.
FFPM571
Nashvillle
Nobody is putting anyone down its a fact. Before just slam anything into an XTS some research should be done its not a hobby grade radio.
jaspence
Michigan
My experience with VHF and 800 MHz XTS3000 radios is that the CPS will not let you send a code plug with errors to the radio. There is a choice in one of the menu items that looks for errors to help you fix them. If you somehow force a bad code plug into the radio, you can brick the radio.
marcotor
I ♥ÆS Ø
Sunny SoCal
Welcome to RR.
That's a general statement which is factually incorrect. I have purchased dozens of Motorola ASTRO25 radios from eBay - XTS and XTL models, and not one was locked.
FFPM571
Nashvillle
I've bought dozens of Astro and Astro25 radios on Ebay and have only gotten one with an ASK. which I fixed I have also bought two of the same former DCPD radios one was an XTS and the other was an astro saber. and it is in no way were either locked down.. Its just someone who doesn't know what they are doing..
