Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 03-23-2018, 11:45 PM
Angry Programming Problem
Hello all, I'm having an issue with my CPS I have an older prolific drivers installed so I'm not getting a code 10 error but when I load into CPS I hit for it to read my COM3 it start to not respond I tried waiting 15 minutes and it didn't work, any ideas
Old 03-24-2018, 8:57 AM
chief21's Avatar
Have you looked in Windows Device Manager to confirm that the driver is loaded correctly and that the associated com port is actually COM3?
Old 03-24-2018, 9:06 AM
I'm not trying to be nit picking, but it would help to provide the version of Windows your trying to use on your computer and which radio your trying to program. Also providing the version of the CPS your using could help as there are some versions of some radio software that have known problems.
Jim
Old 03-24-2018, 11:10 AM
Yes, everythings there, I'm using windows 10 I just bought a FDTI cable due to the USB Prolific Fakes hopefully it works, PPCPS is R05.02.04
Old 03-24-2018, 11:57 AM
MCore25's Avatar
So you are programming a radio for Privacy Plus? While never really dealing with the Privacy Plus CPS I can tell the issue you are having is almost identical to the issue I have with Waris (Profesional series) CPS using a 64 bit machine running either Windows 7 or Windows 10. Only work around I've found is to use a 32 bit machine. I typically use the IOGear RS232 to USB adapter (it also happens to be the one recommended by Motorola) if I need the adapter.
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you…
Old 03-24-2018, 10:16 PM
Its PassPortCPS
Old 03-25-2018, 3:05 PM
johnkoellmer24's Avatar
Location: litchfield county (NWCT) / schoharie county (NY)
Question mototrbo xpr 6550 error 1687 message
hello all
I have a xpr6550 portable radio and I am using the latest software 15.0 and my radio firmware is R01.12.17 and the CPS VER. 13.02.03 and I keep getting the error message when I connect it with the programming cable PMKN4012A and PMKN4012B.
Please help thanks
(photo below is what the error message says)
Tags
cps, ht1250, new to programming
