Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 04-13-2018, 8:31 PM
Default CDM1250
I have a cdm1250 (aam25rkd9aa2an) with a corrupt codeplug and did not save the original one now will not read in cps does anyone have same model that could send me the a codeplug doesn't matter what's on it as long as I could re write it and get the radio back to working status would be appreciated thank you
Monitoring the bands with a few Motorola's
Old 04-14-2018, 7:21 AM
druhe's Avatar
This site may have what you need
http://www.codeplugsupersite.com/
Also there is a file within the CPS with blank codeplugs, but for the life of me I can not remember the name of it
--Dan-- KE3UC
Old 04-14-2018, 10:36 AM
If your CPS is installed correctly, you will find sample codeplugs for all models of mobiles and portables in a sub-folder labeled SAMPLES on your computer. C; ---> Program Files ---> Motorola ---> Professional Series CPS ---> Samples
I found this on a similar topic from a couple years ago. From a knowledgeable RR user/contributed.
Old 04-15-2018, 7:39 PM
Thanks for the input still can't get it going found a radio with same model number and tried to write it and didn't work someone said it had to be blank I'm unsure what else to do at this point might have become a paper weight
Old 04-16-2018, 7:42 PM
Skypilot007's Avatar
So writing the matching sample code plug from the sample folder in your CPS did not fix the problem?
Old 04-16-2018, 8:56 PM
I have R06.12.08 and couldnt find the matching model number in the samples
Old 04-17-2018, 7:18 PM
What's the tanapa code from the radio's label?
Old 04-18-2018, 1:06 PM
I cant even get CPS to read from my CDM1250's.... It keeps telling me to check my cables.
