Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 06-07-2018, 11:55 AM
Default APX8000 Keys Locked
Is there a setting on the APX software where when you turn the radio on it is essentially locked, none of the buttons work and the keypad, switches and dials are all locked out until you hit the PTT. Once you hit the PTT it opens the radio up and you can change channels and change inputs. Has anyone experienced this? I couldn’t find a systemwide setting that indicates a radio lock out. Also be advised that none of my programmable switches are assigned any type of lock.
Old 06-07-2018, 10:28 PM
bk117's Avatar
Sounds like it is encrypted with a CCI algorithm. Do you work for the NSA?
Old 06-08-2018, 11:58 PM
Sounds like you have a radio that belongs to the federal gov't.
Old 06-10-2018, 2:52 PM
I was't referring to any encryption keys. I was referring to tactile keys (key pad, switches, other buttons)
Old 06-10-2018, 3:33 PM
The issue with not being able to use to radio without first clicking the PTT is indicative of a Controlled Cryptographic Item.
Old 06-10-2018, 5:50 PM
bk117's Avatar
Where did you acquire this radio?
Old 06-12-2018, 8:20 PM
Probably off ebay lol
Bryan N4EBC
Old 06-13-2018, 3:40 PM
SimpleSkye's Avatar
Does it say anything on the screen before the PTT is pressed?
Old 06-13-2018, 4:01 PM
+1.
Old 06-14-2018, 2:18 PM
Location: New York North Carolina and all points in between
The radio may also be programmed to "log on" to the system before it is allowed to power up. I seen a bunch of XTS5000 that I bought at a Fed auction that required that, and out of the dozen 4 were stunned and would not power up until I reprogrammed them with D.
