Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 06-13-2018, 4:49 PM
Angry XPR 7550e programming problems
Alright, I have the newest software 15.5, I have the correct cable 4012B, I even tried connecting to the bluetooth. I have also gone to this web page https://support.smartptt.com/hc/en-u...-radio-via-CPS and did everything that is in here. MY RADIO STILL WON'T READ! What in the actual $#@! am I doing wrong here? This damn radio is driving me out of my mind, thank god it isn't mine! Please, any help is appreciated.
Living the dream
Old 06-13-2018, 5:11 PM
Have you taken a fine screw driver or dental pick and lightly scraped the gold programming contacts on the side of the radio before connecting the programming cable? Do you get the Bing bong of the radio being discovered by windows once connected? Is this a gray market or other hacked type of radio? Thanks, TT.
Old 06-13-2018, 6:11 PM
N1GTL's Avatar
Your link points to SmartPTT's website. First, my condolences if you're using that product.
You don't mention your OS. MotoOnline has a USB driver file you can install. I have found that on some computers, I have had to run that USB driver installation.
Connecticut Database Administrator
Old 06-13-2018, 6:46 PM
MCore25's Avatar
CPS 16.0 is the newest version. Been out for a few days now.
What’s the error you are getting and what is the setup?
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you…
Old 06-13-2018, 8:57 PM
What error are you getting? Is it a North America radio with the North America software?
Motorola XPR6550, HT1250, CDM1550LS+, XTS5000, CP200, CP150, 2 MCS2000, 2 I355
TYT MD380
Baofeng UV5R
Kenwood TK880
Old 06-13-2018, 9:12 PM
The radio itself and cable are brand new. It makes the noise that connects. The error message after the wheel spins says it couldn’t communicate with the device. I have windows 7 professional if I’m not mistaken. I didn’t buy anything from there I just searched problems programming the radio and their site came up.
Living the dream
Old 06-13-2018, 9:18 PM
windows 7pro SP1 to be exact
Living the dream
Old 06-14-2018, 3:14 AM
Have you read/programmed other DMR radios from this same set up?
FORMERLY MOONBOOTS
Old 06-14-2018, 4:47 AM
Are you using the right Comm port?
TYT MD380
Baofeng UV5R
Kenwood TK880
Old 06-14-2018, 10:32 AM
Yes I have done other XPr’s on this computer with no issue.
Living the dream
Old 06-14-2018, 11:20 AM
MCore25's Avatar
If comm ports are an issue...you are doing it wrong.
Old 06-14-2018, 2:42 PM
But, you could have an IP / IP route conflict.
Use ipconfig & netstat -rn to determine if you have an issue.
Old 06-17-2018, 9:20 AM
You're assuming he knows how to do all that......
I would try and use the latest CPS with Windows 10 if you can.
Although if you are getting the Bing Bong of windows recognizing the device and not able to Read then it seems to be an issue with the Radio and not the Software or Windows.
Brian
N4EBC
WRBT512 GMRS
Old 06-18-2018, 8:55 AM
There could be an issue with your computers wifi or ethernet port causing a conflict. I suggest disconnecting ether and wifi and trying again. Typically, the radio sets up an ethernet connection in the 192.168.10.x subnet. If you have another network connected in the same subnet, then you will have issues. TT
