Minitor II Pager amp question
xxbryantd
I have a minitor 2 pager amp that im trying to find a spot that it powered only on alert. Does anyone know where on the pcb i can solder a trigger wire to?
ffexpCP
wizard of odd
Michigan
Yes.
Is there a din connection on the amp? If so, it has a momentary output.
Then if all else fails, use the pager's contacts. I think it's the last pin opposite the charging contacts that triggers the 'alert' led on the charger.
xxbryantd
Yes.
Forgot it in my original post, but it does no have a din connection.
