Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 08-10-2018, 7:03 PM
Default Can I charge an HT1250 LS+ using my XTS IMPRES desk charger?
Can I charge an HT1250 LS+ using my XTS IMPRES desk charger? IMPRES Desk Charger: WPLN4114AR
Conventional is better than trunking....
Old 08-10-2018, 7:04 PM
com501's Avatar
No, not unless you have a battery adapter.
Making your scanner useless, county by county.
Encryption, it pays my mortgage.
Old 08-10-2018, 8:23 PM
The battery will fit, but the charging contacts are lower on the battery. So years ago the trick was to put some quarters under the radio, so it’s raised 1/4-3/8”. Then the contacts will line up.
FORMERLY MOONBOOTS
Old 08-11-2018, 1:44 AM
Originally Posted by N4KVE View Post
The battery will fit, but the charging contacts are lower on the battery. So years ago the trick was to put some quarters under the radio, so its raised 1/4-3/8. Then the contacts will line up.
Thats awesome! Thanks for the tip, I just need to be able to charge it enough to turn it on and test it.
Old 08-11-2018, 11:03 AM
I once had a charger go out and ended up making a mold since I was into the 1/18 scale models craft work wasn't a issue. Just did a mold then made a plastic adapter.
I haven't got much into the 3d printing but I've seen some create some interesting things for radios including a modified ht1250 housing that was taller.
