Honda-ST1300PA
- Joined
- May 5, 2018
- Messages
- 79
Need some assistance with setting up Zone selection using the ABC toggle switch.
The rotary is set for channel selection and the concentric ring for scan mode; both work fine. Inputting Zone Select into any or all of the Three Position Toggle fields results with an invalid fields error pointing back to these same fields for Conventional and Trunking. The Trunking values are set to blank (also tried unprogrammed) for the Three Position Toggle fields.
The Zone Channel Assignment is:
Z1: Tac1
Z2: Tac2, Tac22
Z3: Tac3, Tac31, Tac32, Tac33
Z4: Tac4
Z5: Tac5
The Zone selection works fine on the soft buttons, but Id like to use the ABC switch to pick Zones 1-3.
Is this possible?
Z1: Tac1
Z2: Tac2, Tac22
Z4: Tac4
Z5: Tac5
Is this possible?
