Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 12-06-2018, 9:37 PM
Smile band split
our department went on a new channel it is 460.13750 can i use a 450-520 mhz uhf radio im not sure if im correct any help would be good thanks.
Old 12-06-2018, 9:41 PM
Default band split
Yes, 460.xxx falls between 450-520 and will work.
Old 12-06-2018, 10:16 PM
Any freq between 450-470 can be used on a high, or low split radio.
FORMERLY MOONBOOTS
Old 12-06-2018, 10:26 PM
alcahuete's Avatar
Frequency-wise, yes, the above answers are correct. However, is it analog, digital, etc.? If they went digital, then a standard 450-520 MHz analog radio is not going to work, for example. A DMR radio is not going to work for P25, and vice versa.
There is a lot more to figure out than just the frequency alone.
Old 12-06-2018, 11:44 PM
mancow's Avatar
Depends on the radio.
Old 12-07-2018, 7:07 AM
ecps92's Avatar
Contact your Radio Shop [Techs / Company]
Too many variables
a. Is your Radio Narrowband
b. Did they go digital
c. Did they go from PL to DPL
With all the above, the question begins of
a. Does your Radio Support
We won't even get into the permission to put a radio on a channel licensed not by you [you need to ask and get written permission]
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
