Go Back   The RadioReference.com Forums > The RadioReference Tavern > Movies / Television
Movies / Television Fifty-million channels and nothing is on. Maybe someone here knows?
Old 06-28-2009, 09:32 AM
Talking radio that receives digital tv?
Now that OTA TV signals have officially made the switch from analog to digital I was wondering if anyones knows of any radio in the works that will be manufactured to receive them??
Ive been asked from some coworkers who now can no longer listen to thier soaps while at work.
IC-R20,BC-780XLT,PRO-64, PRO-95,PRO-96,PR0-2096,BCD396T, BCD996T,IC-R2500,IC-2820H,PRO-197
Old 06-28-2009, 09:43 AM
N_Jay's Avatar
Just as TV band radios exist (but as a small market) I would bet there will be new ones (but it will take a while until the receiver/tuner chips get cheap enough)
Or the market goes away and is replaced with Internet streaming to a phone or computer.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 07-03-2009, 11:47 PM
CLynch7's Avatar
Hopefully a radio like that comes out someday soon. Then it can be expected that portable tvs will be soon behind. I'd like to see a 6" or so LCD portable. Bring back porta-tv DXing.
Chris, KJ4MPT
Radio Shack Pro-51, Pro-75, Pro-83
Grundig G5, G6 Aviator, TRII Digital
GE 7-2990A, Kenwood TH-78a Dual Band
Old 07-04-2009, 10:57 AM
gmclam's Avatar
What is happening is leiu of radios that get TV sound is a new industry called mobile TV. Services are available in many areas to get TV on your cell phone and/or specialized hand-held devices. One system is using the old TV channel 55 around the USA to broadcast 8 channels digitally to hand-held units. It's digital so the pictures are "clear". Oh you want it for free? Not for a while.
PRO-95 | (customized) PRO-10 | PRO-97 | PRO-77 (customized) | PRO-92 | PSR-300
Old 07-05-2009, 10:10 PM
N_Jay's Avatar
Originally Posted by gmclam View Post
. . . .One system is using the old TV channel 55 around the USA to broadcast 8 channels digitally to hand-held units. It's digital so the pictures are "clear". . . . ..
Link?
Old 07-05-2009, 11:47 PM
n5ims's Avatar
Originally Posted by N_Jay View Post
Link?
MediaFLO
MediaFLO - Wikipedia, the free encyclopedia
Hope that these help.
Old 07-23-2009, 02:58 AM
Gday, I had been thinking about trying something like that with digital tv and a analog scanner. I have got a old SD Set top box with a blown power supply that I thought may be possible to use the codec IC to "Decode" the Digital audio, I know this would have to also have a A-D / Codec IC / D-A type of circuit. I have not yet started because I am still researching this and do not know if Baseband (Discriminator) audio would be sufficiant or would need to have a 10.7 MHz output.
James.
Old 07-23-2009, 03:07 AM
gmclam's Avatar
To receive over-the-air TV audio in the USA from a digital braodcast you need to do the following. My outline is by no means absolutely every step, but merely an overview.
- Tune to the correct frequency; which is a 6 MHz wide signal
- Demodulate the digital transport stream, which uses 8VSB
- Parse the stream to find the desired audio data
Note: keep in mind that a typical ATSC signal has PSIP data, guide data plus video & audio for multiple channels. You are not going to be able to just grab all the audio packets, you'll need to determine which sub-channel's packets you want.
- Convert the audio data into audio (digital to analog conversion)
- Optionally modulate the audio onto a frequency your scanner can tune to
There's no real way to send the signal to the scanner as an "IF" signal, other than perhaps remodulate it yourself because no current scanner can underestand 8VSB nor is it able to do most of the processing required.
We're not dealing with FM audio, so there is no discriminator involved (other than in your scanner). Using a 10.7 MHz output would only work if you remodulate the audio onto 10.7 MHz and you can tune that frequency on your scanner.
Old 07-23-2009, 08:07 AM
jhooten's Avatar
7" Digital portables have been avaiable for a while now. I've had mine for 4 months and it works fine. Rat shack had them on sale for $129. They were back up to $179 for the least expensive last time I checked.
Jerry
I read it on the internet, so it must be true.
Old 07-23-2009, 10:34 AM
i have a 5 in portable LCD tv that does ATSC and NTSC as well as having a composite A/V input. Payed something like $30 for it brand new.
Old 09-02-2009, 07:00 AM
KB9NLL's Avatar
Location: Appleton (Outagamie Co. WI) & Readfield (waupaca co.)
I've seen 2 different kinds for hooking to a usb drive one in a beginning of the year catalog and one at ratshack a few months ago Hauppauge® WinTV-HVR850 USB TV Tuner - RadioShack.com .
Includes portable antenna to receive digital TV while you travel
Works with both analog and digital television broadcasts
Dimensions 1x4x5 inches & 4 ounces
$79.99 for this one remove the video half, put it into a radio lol.
Amateur Radio-1996 scanners-1995 other radios-1990
Used daily: Pro-96, Yaesu VX-7R, more
"I reject your reality and substitute my own"-Adam Savage
Old 11-01-2009, 01:12 AM
I see a lot of ideas here, and experimentation is the name of the game to find out what works. If I had the time, I would take one of these TV boxes that the FCC or whoever gave the coupons out for, and try to wire the audio portion to a radio compatible with digital signal reception. Some receiver stages and components would have to be worked with or even completely replaced. I'm betting that someone somewhere would figure it out.
Old 11-01-2009, 05:50 AM
scottaschultz's Avatar
Newegg has this for $54.99!
Newegg.com - Hauppauge WinTV-HVR-850 HDTV Adapter 1200 USB 2.0 Interface - TV Tuners & Video Devices
The reviews aren't exactly stellar, but the key seems to be having a good antenna. I have an internal PCI tuner card and I am very pleased with it. I bought a 1tb hard drive for $80 and now can record days worth of HD video on my PC.
Scott - NØIU
Old 11-01-2009, 09:07 AM
N_Jay's Avatar
I haven't cracked mine open, but I am betting that the video and audio are all decoded in one chip.
Most of the boxes deliver baseband audio, so I don't know what you would be wiring it to besides an amplifier.
(Yes some are RF only out, but the ones with video and audio out were easy enough to find, that I found no reason not to get them.)
[IMG] code is Off
Similar Threads
Lee County: Another agency drinks the digital Kool-Aid WiFI_AES Florida Radio Discussion Forum 0 09-07-2008 07:55 AM
ISP Dist 52 on Greenwood Tower delallen Indiana Radio Discussion Forum 13 05-17-2008 10:45 AM
Radio System troubles exkalibur Trunking Forum 33 11-05-2007 08:18 AM
Statewide Trunked System Information blantonl Virginia Radio Discussion Forum 0 09-11-2004 09:30 AM
