Originally Posted by jacobsmith
Does TETRA use "NAC" I'm sure it's not called this on TETRA but do they use special codes to mute other traffic on DMO mode? If so, what are the codes like? ex: FKF, 123.. thanks.
In TETRA DMO you can associate each channel (= frequency) with a GSSI - Group Short Subscriber Identity, so that a radio without the matching GSSI will not be able to listen to the communication.
Since it would be possible to program the channel and GSSI to any TETRA radio (assuming you have the required knowledge and tools) encryption can be applied by associating a SCK - Static Cypher Key with each DMO channel/GSSI, preventing eaves-dropping.
