Originally Posted by pyeman99
I had trouble get Trunkview to control the radio.By default the com port of a PCR runs at 38400.So I wrongly set Trunview to this.Resetting to 9600 fixed the problem.
It also takes quite a bit of working out with a calculator to get the correct setting for offset,base freq etc.I now have some info that works ok for Mid Band (162 to 165) systems for UK if anyone does get stuck.
Still some to learn but looks like a good program.
Keith.UK.
Trunkview should set the comms on the PC-R100/PC-R1000 when it initialises so that should not be a problem?
Offset can be left at 2 and never altered (it's a legacy of the original linux software and will be removed in a future version of TrunkView to prevent the confusion it causes!). One thing less to worry about when you are playing with your calculator then
Several systems documented on the TrunkView yahoo list:
http://groups.yahoo.com/group/trunkview
If people get stuck it's better to explain what to do rather than spoon-feed them the settings for a system.
There is a page on the Trunkview website (
http://www.linato.net/trunkview/ ) which explains, fairly clearly, how to work out the base frequency for a system with a logical channel plan.
TrunkView will not track systems that use a custom channel plan.
