Go Back   The RadioReference.com Forums > Commercial and Professional Radio > MPT-1327 and TETRA Forum
MPT-1327 and TETRA Forum For general discussion of MPT-1327 and TETRA Trunking Technologies
Old 04-24-2007, 07:49 PM
JLM7424's Avatar
Question Help With ?
Is their a scanner that can scan the mpt 1327 radio systems?
thanks any answers appreciated
My Signal Interceptors.... | Yupiteru MVT-7100 | Psr-600 | Bcd-396T |
Old 04-24-2007, 09:46 PM
The short answer is NO - but it depends on how you define 'scanner' and 'scan'.
The scanners in your tagline will monitor the individual channels used on an MPT1327 system, but they aren't able to decode the Control Channel information.
There are no scanners currently available, that will monitor MPT1327 systems in the same manner that your scanners will monitor Motorola, EDACS, or LTR.
WinRadio has a module (software) that allows decoding of MPT1327 signals, but is it a 'scanner'?
There are also hardware/software arrangements known as FTrunk and PTrunk, but would you call them 'scanners'?
Old 04-25-2007, 01:41 PM
Question
Hey there,
It looks like I am not the only person that has found a mpt system in the state have you figured out what agency etc it might be? I have linked mine to Basin electrict off of a tower in Clay County.
Monty N Haynes
Old 04-25-2007, 03:20 PM
cg cg is offline
There are several decoders that will show the activity on the MPT1327 systems and are free (and they work).
Unitrunker (forum here) and Trunkview (search Yahoo Groups)
Both will control a computer controllable scanner, do some research online as how to hook each up. I have success feeding them from the speaker rather than from discriminator.
chris
Old 04-25-2007, 08:21 PM
MPT1327 is fairly slow data and doesn't really need a "discriminator tap" to work well with PC-based decoding
Old 04-26-2007, 01:05 AM
Seņor Member
That's true. For those systems that inject a sub-audible tone on the control channel, using speaker audio - instead of unfiltered discriminator audio - will produce better results.
Old 04-26-2007, 08:27 AM
Question
ok
well on mine the control channel is 452.6500 but on Trunkview it says 420 so can anybody explain how this works
Monty N Haynes
Old 04-26-2007, 11:28 AM
You need to set up a "site" entry for your system so it knows what the channel plan is for the specific system.
Old 04-26-2007, 11:33 AM
cg cg is offline
Unitrunker is probably better for a new user. Otherwise, you would probably need to join the Trunkview Yahoo Group and (after searching the archives of course) ask the question there.
chris
Old 04-30-2007, 04:01 AM
Default MPT1327 capable scanner
Hello from France,
Last year , i asked to Uniden Europe the availability of such scanners . The answer was NO . Just a question of numbers of scanners sold in Europe !! (not enough)
Uniden succeded in APCO25 scanner , they could do TETRA also !!
