Go Back   The RadioReference.com Forums > Commercial and Professional Radio > MPT-1327 and TETRA Forum
MPT-1327 and TETRA Forum For general discussion of MPT-1327 and TETRA Trunking Technologies
Old 07-28-2007, 08:43 AM
Default TrunkView 2.0/BCD396T Incompatibilty
You'll see a similar post in the Uniden section. I apologize for the cross-post, but I'm desperately looking for a fix for my scanner, and I also feel I should warn anyone with a 396 who is thinking of trying TrunkView 2.00.
Long story short, after running the band scan feature on TrunkView 2.0, my 396 now drops ANY signal every two seconds, for the duration of about half a second. This seems to be the interval the TrunkView band scan was controlling the receiver with, but now my 396 drops the signal every two seconds even when TrunkView is not being used.
Reloading the Uniden firmware and previous configuration hasn't fixed the problem. Now I'm off to the TV Yahoo group to see if they can help. Unless there's something I'm overlooking, I would STRONGLY recommend anyone with a Uniden 396T to stay away from TrunkView 2.00.
Old 07-28-2007, 11:35 AM
I fixed the problem by reseting the scanner's memory. I think I'll lay off the MPT1327 stuff for a while................
Old 07-28-2007, 11:38 AM
Saint's Avatar
Smile Mpt1327
Use Unitrunker for decoding MPT1327, it works perfect.
Steve
BC396T Scanner
Pro-2045 Scanner Discriminator Tap
ARC396TPRO Software
Old 07-28-2007, 01:31 PM
DaveNF2G's Avatar
So you've posted two separate threads slamming a piece of software that is not at fault in your problem. Nice.
Old 07-28-2007, 05:43 PM
Steve
It might work reasonably well but Trunkview has a whole host of features that Unitrunker doesn't. I like Unitrunker for Motorola systems.
As for the original post.......I've been running TV with a 396T since the beta control for it was introduced and have had no problems with the radio.
Old 07-29-2007, 09:19 AM
UPMan's Avatar
Uniden Product Manager
If audio was dropping every 2 seconds then either Close Call or Priority got turned on. Likely has nothing to do with the software (unless the software sent an erroneous command to turn on the feature).
Got a question? Ask it in a public forum for faster response.
My solar power station
Old 07-29-2007, 11:20 AM
Originally Posted by UPMan
If audio was dropping every 2 seconds then either Close Call or Priority got turned on. Likely han nothing to do with the software (unless the software sent an erroneous command to turn on the feature).
Trunkview initiates and starts a quicksearch - it does nothing to Close Call or Priority settings.
Old 07-30-2007, 09:52 AM
Napalm's Avatar
Just to add to what Morfis said...
With a scanner that has a "front panel" and controls, there's no need to use Trunkview's Bandscan feature. Might as well initiate your own search from the controls on the radio - the radio's own search is much faster than TV anyway.
FYI's, I just ran the Bandscan from trunkview on my BCT-15 and neither CC nor Priority were enabled after I came out of the scan.
I'd politely suggest it was user error in this case.
Originally Posted by Napalm
Love is a Motorola XTS3000
Old 07-31-2007, 01:06 AM
Seņor Member
Those were my thoughts too.
TV most definitely does. UniTrunker provides basic decoding. Having the program control the radio that provides the control data so that the software knows the exact frequency of the current control channel would allow any program to do a better job of distinguishing two or more systems programmed with the same system ID - a common problem with MPT1327 systems. On of these days I'll get around to that.
Old 07-31-2007, 05:12 AM
Originally Posted by Unitrunker
..... allow any program to do a better job of distinguishing two or more systems programmed with the same system ID - a common problem with MPT1327 systems. On of these days I'll get around to that.
Is this a common problem in the US? My experience around Europe and the East has been otherwise.
I'll look forward to the Unitrunker version that incluses the features from TrunkView/PTrunk/Trunksniffer Pro and therefore to be able to use it exclusively
Old 07-31-2007, 11:00 PM
Seņor Member
Must be. Lots of 2309 and/or 2319 system ids.
Old 08-01-2007, 09:09 AM
In the same radio area?
System Idents are re-used but not usually within the same geographical proximity.
Life would be easier if the sysid was allocated centrally like the Motorola ones - though I have never come across two systems with the same ID causing each other problems (limited monitoring of civvy stuff in the USA)
Old 08-01-2007, 12:45 PM
Jay911's Avatar
Send a message via ICQ to Jay911 Send a message via AIM to Jay911 Send a message via MSN to Jay911 Send a message via Yahoo to Jay911
Yes; I described this back when I was using TV. 3 systems in my area (were) using 2319.
--j.
VE6SRT
Old 08-01-2007, 12:56 PM
Have you tried monitoring them with the most recent version of TV? It allows you to have multiple sites with the same ID but differing profiles and select the relevent one when monitoring.
(probably ought to be a separate thread now)
Old 08-01-2007, 05:19 PM
pyeman99's Avatar
Smile
I'm using TV 2 ,no problem with 396 in UK works quite normally.
Set up as UP Man says.
Regards Keith.
Similar Threads
TrunkView V2.00 released. Comint MPT-1327 and TETRA Forum 8 07-27-2007 04:53 PM
Trunkview V1.50 released morfis MPT-1327 and TETRA Forum 15 06-07-2007 08:27 PM
Trunkview 1.3 with Icom PCR-* pyeman99 MPT-1327 and TETRA Forum 5 11-11-2006 06:02 PM
Trunkview V1.3 morfis MPT-1327 and TETRA Forum 8 10-14-2006 03:58 AM
Trunkview V1.21 Pacmonitor MPT-1327 and TETRA Forum 28 07-01-2006 04:59 PM
