Go Back   The RadioReference.com Forums > Commercial and Professional Radio > MPT-1327 and TETRA Forum
MPT-1327 and TETRA Forum For general discussion of MPT-1327 and TETRA Trunking Technologies
Old 01-15-2005, 05:42 PM
Saint's Avatar
Default How to set ini file in Tronquito
I have a mpt 1327 system I'm trying to listen to in the 400.00 mhz band, the control channel I am listening to is 420.175 how do I set up the .ini file to listen to it.
This is what I have started to receive
New network...
SYS 0x50a1 Unknown network - C.C. 460.0000 MHz
SYS 0x50a1 ACKK General Prefix: 0x0 Ident1: 0x1ff9
SYS 0x50a1 GTC Channel 0x26 Freq: 460.4750 Mhz Prefix: 0x0 Ident1: 0x1774 Voice
SYS 0x50a1 GTC Channel 0x26 Freq: 460.4750 Mhz Prefix: 0x0 Ident1: 0x10b Voice
SYS 0x50a1 ALOHA
This is the way the file is set now
[0x4009]
Base=4600000
Offset=2
Step=125
CC=4609000
Name="(UHF) T1"
Steve
BC396T Scanner
Pro-2045 Scanner Discriminator Tap
ARC396TPRO Software
Old 01-23-2005, 11:05 AM
pm sent Steve
Old 02-01-2005, 06:58 PM
Have you been able to figure this one out Steve? From the look of it, the base would be 420.0000, step 125 (12.5kHz). The offset might need to be tweeked; for some reason I found it to be off 1 or 2 channels from expected (built-in compensation?). Watch the channel frequency it reports during a call, and adjust if necessary.
I found one system where the step is actually 6.25kHz even though the channels are on 12.5kHz grid. The S/W truncates the last digit, causing roundoff errors that increase with the channel number (I verified this). This shouldn't be a problem in your case (I hope).
Dave
Old 02-01-2005, 07:38 PM
Saint's Avatar
Hi Dave, I really have not had any luck with the program and deleted it, I know that other people are working on new programs that will be a lot better, so I think I will just wait till these programs come out, I just wanted to play around with the program to see what it will do. To bad there is not a scanner radio that will trunked this kind of system, anyway thanks for the info Dave.
Steve
BC396T Scanner
ARC396TPRO Software
