Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Multi-State Communications Networks
Multi-State Communications Networks - The purpose of this forum is for discussion of trunked or conventional communications networks that span more than one state. They are local government or commercial in nature. For Federal or Military use the appropriate Topic Specific forum.
Old 01-29-2018, 8:18 AM
wa8pyr's Avatar
Technischer Guru
Default TRBOconnect IL/IN/KY/OH
This thread is for discussion of the ERS-OCI Wireless TRBOconnect system(s) covering Indiana and parts of Illinois, Kentucky and Ohio.
Please post all queries, findings, etc in this thread.
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535/BCD436HP/TRX-1
Old 01-29-2018, 12:30 PM
mtindor's Avatar
OH/WV DB Admin
Thank you, Tom!
mike
Old 02-27-2018, 9:59 AM
wa8pyr's Avatar
Technischer Guru
Default "Stadium" site
All,
A submission has been made for the "Stadium Repeater" on this system. Info:
001 (1) Stadium Repeater
01 461.2375
02 461.6875
03 462.1625
04 463.2375
05 463.6375
06 463.9125
07 464.5875
08 464.8625
The submission identifies it as Site 1 (a number already in use), but gives no other identifying information such as county, location, color codes, etc.
I've not gotten a response from the original submitter as to this information; research shows some of the frequencies licensed in the Bloomington, IN area, fairly close to the IU campus, but not enough to convince me that's actually the location.
Unless someone can fill in the blanks I'm going to have to reject this submission as incomplete.
Tom Swisher, WA8PYR
Old 02-27-2018, 11:39 AM
mtindor's Avatar
OH/WV DB Admin
<deleted -- not necessary>
Old 02-27-2018, 12:05 PM
mtindor's Avatar
OH/WV DB Admin
Originally Posted by wa8pyr View Post
All,
01 461.2375
02 461.6875
03 462.1625
04 463.2375
05 463.6375
06 463.9125
07 464.5875
08 464.8625
Here it is -- Lucas Oil Stadium (actually licensed as Indiana Convention Center but license says its for Lucas Oil Stadium) in Indy.
https://www.radioreference.com/apps/...llsign=WQIX923
Already in the DB: https://www.radioreference.com/apps/db/?sid=9454
Mike / AA8IA
PSR500/PRO197/BCD436HP/TRX-1
Email: my username @gmail
Old 03-22-2018, 7:21 AM
milf's Avatar
Careful, I CAN hear you!
The system is for both Lucas Oil Stadium and the Indiana Convention Center. They are one complex. Most legal paperwork IDs the whole system as LOSICC or LOS/ICC.. (I attend at least 3 conventions there yearly.)
APX6000XE, SD-5R (On Way)
Old 07-09-2018, 6:10 AM
mtindor's Avatar
OH/WV DB Admin
Tropo this morning from the west. This site is likely in northern Indiana, such as Peru (Miami) or Bluffton (Wells) given it's neighbor list, although sites 3/9 are not known in the DB and site 10 doesn't exist in the DB.
464.6125 CC
127-11
DCC:9
CON+
NL: 3, 9, 10
Mike / AA8IA
Old 07-09-2018, 9:32 AM
milf's Avatar
There are several sites we have not locked down yet, and still a couple that are being built out. And I believe they still have a couple of LTR and Moto Legacy systems to convert and add in. I keep pushing hard to get folks to jump on this system and help lock it down as it is going to go Statewide by 2020.
Old 07-09-2018, 12:28 PM
mtindor's Avatar
OH/WV DB Admin
I'd suspect Site 11 to be Bluffton -- based upon FCC license, site neighbors, and location to those site neighbors. All other ERS licenses that have 464.6125 are too far away for those locations to be neighbors of sites 3 / 9 / 10. Not to mention the fact that Bluffton is closer to me than any other site.
I have occasionally heard some of the other identified single-digit sites in the past, but of course from my location it was not possible to pinpoint them to anything other than NEIN or NWOH, especially with the 454 mhz spectrum being used on some of them.
I question Granger in the DB, simply because, according to the DB, New Castle reports Site 21 as a neighbor. It's a far stretch from New Castle to Grainger, with many active sites in between -- and Grainger licenses are also the same locations as MIshawaka (which does seem correct as Site 18).
Mike / AA8IA
Old 07-10-2018, 2:29 PM
Smile Site 13 Neighbor List
Gentlemen,
Watching this thread carefully, since I spend a little time in the Richmond area (Wayne Co) every now and then...
Pulled my "notes" from a field excursion a little bit back and have info on Site 13 (Richmond) that shows that its NL was as follows:
Site 10 - ???
Site 13 - Richmond (Wayne Co)
Site 14 - Anderson (Madison Co)
Site 26 - ???
Site 29 - New Castle (Henry Co)
Unfortunately, there was virtually no traffic at the time I was running DSD+ on Site 13, so I was not able to get LCN's for it. I want to say that I believe Site 26 may, big MAY here, be Connersville (Fayette Co) (WPPV349) site...
Going to try to help as much as I can with this system; however, since I live in Preble Co, Ohio, it makes it a little bit of "work" to get information. But, I will contribute as much as I can, when I can....
Hope this helps,
Dave T.
Preble County, Ohio
Whistler TRX-1 / Uniden BCD436HP (x2) / PRO-106 / DSD+ w/ Laptop
Old 07-12-2018, 8:34 AM
mtindor's Avatar
OH/WV DB Admin
For anybody who (a) is within earshot of one or more sites in the DB and (b) is capable of using DSDPlus to obtain Site neighbor information (and LCN info), please consider parking on the control channel for a while and gathering/submitting info.
NOTE: Just because one frequency on a site might be listed on a CC doesn't mean that there aren't other control channels. If you do not pick up a DMR CON+ signal on the listed control channel and feel you should, check the other frequencies associated with that site.
There are many sites with no site neighbor information. We definitely could benefit from having that information from those sites which lack that information. But, even if a site does have site neighbor information it would be nice to have the latest site neighbor listing for each site (in case the neighbor lists have changed).
I do have a question about LCN order (and this is directed to milf and KD4YGG) -- Are all of those LCNS / LCN order confirmed? It appears that all frequencies associated with a site license might have been added and that LCNs might not be confirmed. And if the LCNs are not confirmed, all nonconfirmed LCNs should be set to an "invalid" LCN so that people know at a glance whether or not the LCNs need to be confirmed. Or, some other notation should be made to indicate that LCN order isn't confirmed.
On the other hand, if every frequency/LCN is confirmed to be active and accurate, that's a pretty great job you guys have done on sleuthing out that system.
Mike / AA8IA
Old 07-20-2018, 2:07 PM
Cool Little more info...
For anyone interested....
Found some time to do a bit more sleuthing on the Hoosier-side of the line today.... this info was taken during a drive, starting in College Corner, to Liberty, then to Richmond... monitored stationary in those spots with (2) BCD436's, a TRX-1 and a Laptop running DSD+... external antennas on all monitoring devices....
ERS/OCI Connect+ - Indiana (NID: 127)
Site: 7 (Indianapolis) must've been tropo on this one...)
DCC: 4
463.200 - no traffic heard
Site: 10 (Either Muncie <Delaware Co WPPV656> or Marion <Grant Co WPUG943>)
DCC: 10
NL: 9, 11, 13, 14, 26
464.6625 - no traffic heard
Site:13 (Richmond) - site info per RR.com/ again, no traffic to help with LCN's...
DCC: 2
NL: 10, 14, 26, 29
461.4875
Site: 26
DCC: 5
NL: 10, 13, 14, 29, 33
463.2125 LCN #1
463.4625 LCN #2
- Heard TG 26100 talking with dispatch
Site: 29 (New Castle Henry Co) - no traffic to help with LCN's... but, was able to sit on 463.9625 and
have DSD+ pull Site information...
DCC: 12
NL: 13, 21, 26, 30, 33
463.9625
for Site: 26, FCC records have the freqs being used as located in Henry County (New Castle)... and the frequencies being used for Site:29 as located in Fayette County (Connersville)...
Confused now... unless there is the possibility that Sites 26 & 29 should be "switched" around....
Dave T.
Dave T.
Preble County, Ohio
Old 07-20-2018, 3:14 PM
Don't rule out ignorance on behalf of the tech when setting these systems up. I often come in behind these guys and find poor RF install practices, misconfigured sites, incorrect neighbor lists, unlicensed or mis-licensed frequencies, etc. TT
Old 07-20-2018, 9:57 PM
mtindor's Avatar
OH/WV DB Admin
Dave, et al,
I think you are right about Site 26 / Site 29
Site 26
- based upon frequencies (463.2125 / 463.4625)
- based upon site neighbors (10 / 13 / 14 / 29 / 33) New Castle sites smack dab in middle of them
Site 29 is Connersville
- process of elimination - 463.9625 is only licensed to New Castle and Connersville
- based upon site neighbors (13 / 21 / 26 / 30 / 33) Connersville sits in the middle of them
The conundrum:
Mishawaka / Granger - Four licenses - all with the same physical location
- license address: 4 km S of Int SR 23 and Adams Rd
- license city: one says Granger, 3 say Mishawaka
- FCC ASR database shows same location for all four licenses (12990 SR 23, Granger, IN)
Yet, there is a MIshawaka in the DB and a Granger in the DB.
- Site 18 Mishawaka would be correct (based upon neighbors reporting site 18 as a neighbor)
- Site 21 Granger would not be correct (but its listed because 461.65 is only licensed to ERS at Granger)
The only site (per DB) that we know which lists Site 21 as a neighbor is Site 29 Connersville (463.9625). Granger is a long way from Connersville, way to far to be a neighbor.
So there are discrepencies between Site 18 / Site 21. And the question of Site 21 being a neighbor of Site 29 Connersville even though Site 21 Granger is too far away. It could be a programming mistake. It could be a copying mistake / a mistake writing down info for 461.65. If Site 29 and Site 18 were online before all of the other sites in between them, then they could have been neighbors at some point in the past.
Either Site 21 isn't Granger, or Site 29 is erroneously reporting Site 21 _as_ a neighbor, or 461.65 is not the actual frequency that was copied as broadcasting a site ID of 21, or ERS is using somebody else's license down somewhere surrounding Connersville for 461.65 Site 21.
Another note: Site 20
Site 20 isn't listed in the DB, but it is listed as a neighbor of Sites 7, 15, 22 and 34. That would suggest that Site 20 is going to be one of the following: Indianapolis (High School Rd), Bloomington, Bedford, French Lick, Borden or Columbus.
Sure would help if somebody could get a site neighor listing from Sites 25 (Floyds Knob), 28 (North Vernon), 30 (Greensburg) .
My Map: https://goo.gl/2EiCzS
- does not jive completely with the RRDB currently
- red sites with a * suggest that I have a higher confidence of their location
- red balloons suggest I don't have quite as much confidence in them yet
- there are sites in the DB totally missing from the map (since locations of those sites aren't known yet)
- 19 could be Lafayette or Indianapolis (High School Rd) but probably is Lafayette
- 19 probably Lafayette right because site 15 and site 34 report is at a neighbor
- 1 could be ligonier, evansville or lafayette per FCC licensing
- but we already know evansville; lafayette is likely 19, and ligionier would be the other choice
- plus during tropo I copied Site 1. I often copy into NW Ohio during tropo and Ligonier is not out of the question
- but it is unlikely that I would have copied lafayette during tropo without copying a slew of other sites in between
So although my map suggests my doubts about Lafayette and Ligonier, I believe they are correct.
If the map isn't useful to you, just forget about the link
Mike / AA8IA
