Originally Posted by SquierStrat
i would assume if they're system failed, they would no longer be using digital at all, (or any kind of trunking) and if theres no p25, theres no NAC.
P25 (IMBE) is not just trunking you can use it in conventional mode, Cass County does. If the system fails it can send out a failsoft signal and the radio will revert to a pre programmed frequency, if they are programmed that way. If the system would fail the repeaters that the trunking system used would become converntional repeaters. I am wondering if anyone knows if the NAC on the repeaters now would be the same or not.
the only "backup" frequencies that i know of are analog and use a ctcss tone of 156.7
Those are interop frequencies not back up.
Side not if the system would fail the county fire departments would revert to the old UHF channels.
