Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Nebraska Radio Discussion Forum
Nebraska Radio Discussion Forum Forum for discussing Radio Information in the State of Nebraska.
Old 08-06-2009, 07:39 PM
KG4WHM's Avatar
Default ORIN Douglas County Rebanding
I got to play with a rebended radio from a county FD the channel line up changed a little bit with new channels and possibly new talkgroups
A1 COUNTY DISP
A2 OFD DISP
A3 MED DISP
A4-A11 FIRGROUND A4-FIREGOUND A11
A12-A14 LOCAL CHANNELS (now in zone B)
A15 WCFD (Washington County Fire Dispatch)
A16 FIRE 911
B1 COUNTY DISP
B2-B13 FB2-13(Fire Blocks) these will be used during mutliple FD incident These maybe new talkgroups or just reusing current talkgroups
B14 R2R (Radio to Radio)(now is zone A) this is still conventional unknown if it is simplex DIR no longer appears on the screen
B15 VEHILCE REPEATER (now in zone A) conventional unknown frequency
Zone C is the same as OPD Channels
The programmers put a sticker saying flashed with a check mark on the radios that have been rebanded.
I did not see MED 9 in the radio. LifeNet may start contacting FD directly on ORIN.
On a side sounds like LifeNet is using talkgroup 210 for the Omaha area, including dispatching.
Old 08-06-2009, 07:55 PM
KG4WHM's Avatar
License frequencies for rebanding, added to current callsign
851.0125
851.2375
851.275
851.5375
851.5625
851.5875
851.7875
851.950
852.0125
852.225
852.4125
852.5875
852.7125
852.9625
853.2125
853.450
853.475
853.5125
853.7
853.725
853.7625
853.950
Old 08-07-2009, 10:00 PM
KG4WHM's Avatar
The Fire Block channels are the same talkgroups as OFDs Zone B and same order just different name.
example B2 OFD Bat 2 Event is now B2 FB 2.
Old 08-14-2009, 06:43 PM
KG4WHM's Avatar
Got to play with a XTL5K with procom96 running today.
Med9 is now D13 moved from A13.
The radio techs have to go back and reprogram some of the fire911 channels. They programmed the fire911 with the Washington county fire dispatch talkgroup instead of the fire911 talkgroup. It also sounds like the radio tech have screwed up some of the radio IDs aswell.
There is a talkgroup 65534 programmed in the 'blank' channels.
Old 09-07-2009, 09:49 PM
IrvingtonVFD43's Avatar
Send a message via AIM to IrvingtonVFD43
Question
851.0125
851.2375
851.275
851.5375
851.5625
851.5875
851.7875
851.950
852.0125
852.225
852.4125
852.5875
852.7125
852.9625
853.2125
853.450
853.475
853.5125
853.7
853.725
853.7625
853.950
Any word when ORION rebanding will occur??
Rich, Living 1/2 mi north of BNSF MP 24.45 Omaha Line, former BNSF Conductor, Neb. Division, and Firefighter/EMT with Irvington VFD., http://www.irvingtonfire.com/
Old 09-08-2009, 06:04 PM
KG4WHM's Avatar
I don't know exactly when they started reprogramming the radios, I believe sometime in July. On a PDF file that I found on Douglas County's website it said about 80 days to do mobile 180 days to do portables and a total of three days to change the repeaters over.
This was for billing unknown how long it will really take. For the repeaters they are going to have a tech at each site reprogramming one repeater at a time, seven per day.
When they complete the rebanding process the radio tech have to go back ago to remove the old control channels.
The 85x.0125 are the rebanded 800Mhz frequencies they will not be part of the trunking system. For some reason they are listed under the license for the trunking system
Old 09-08-2009, 07:57 PM
I suspect they will do 1 channel a day at all 7 sites. 1 Technician could realistically do that with the
drive time involved.
Really, it isn't that big a deal to move this stuff.
Old 09-08-2009, 09:38 PM
KG4WHM's Avatar
In the report or contract it says that a tech will be a each site and they will change frequencies at each site simultaneously.
65 Days for Mobiles
120 Days for Portables
7 Days for control stations
2 Days for consolettes
Washington County will reband first then, Douglas County and finally OPPD.
Douglas County will serve as back up for Washington County if anything goes wrong.
Here is a link to one of the PDF files I found.The other file I found is from Motorola to the county which has more detailed information.
http://www.co.douglas.ne.us/dept/com..._08_V_G(1).pdf
It says the Saunders County sheriff, Wahoo Fire, NSP, ATF, Pott County Sheriff, Plattsmouth FD, CBPD and CBFD are included in the rebanding process for Douglas County.
Similar Threads
Can Anyone Get These Pics For Me? :OFFTOPIC: landonjensen Virginia Radio Discussion Forum 8 04-14-2009 08:06 AM
REACT... What do they do? Tfitzmaurice89 General Scanning Forum 150 01-15-2009 02:41 AM
42 new feed links and other updates to my site jasonpeoria911 Streaming / Broadcasting / Audio Recording 6 05-01-2007 12:09 AM
Howard County to undergo radio rebanding jwheatley Indiana Radio Discussion Forum 1 03-21-2006 01:50 PM
Whitley COunty in Crisis ShawnCowden Kentucky Radio Discussion Forum 5 06-21-2005 12:15 PM
