Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Nebraska Radio Discussion Forum
Nebraska Radio Discussion Forum Forum for discussing Radio Information in the State of Nebraska.
Old 01-26-2012, 06:41 PM
Kingmobileaudio's Avatar
Send a message via AIM to Kingmobileaudio Send a message via MSN to Kingmobileaudio Send a message via Yahoo to Kingmobileaudio Send a message via Skype™ to Kingmobileaudio
Default N-WIN system help
I'm out of Lincoln and need help picking witch systems to program in to my 996xt with an out door antt.
(402) 937-8578
Old 01-26-2012, 07:17 PM
trsundstrom's Avatar
Did you look at this? Lancaster County, Nebraska (NE) Scanner Frequencies and Radio Frequency Reference
Tom - W2XQ - w2xq.com
RS PRO-2041 & PRO-106
Old 01-26-2012, 07:20 PM
Originally Posted by trsundstrom View Post
Did you look at this? At first glance it looks like all conventional frequencies. Lancaster County, Nebraska (NE) Scanner Frequencies and Radio Frequency Reference
I think you posted in the wrong area?
(402) 937-8578
Old 01-27-2012, 07:32 AM
W0JJK's Avatar
Use the Lincoln and Milford Towers control channels and that should get what you are looking for.
Old 01-30-2012, 06:23 PM
I get Lincoln, Norfolk, full signal. Milford 0-2. This is a base setup with an outdoor antenna. And I never hear anything.
Now I have a 996xt in my pickup with a permanent mount antenna that gets Lincoln, Norfolk, Milford, and like two others full signal? And get alot of traffic at times.
If anyone local that is close that could help and make sure I have my stuff setup the right way that be great.
BTW both scanners have the same programing
Sent from my PG86100 using Tapatalk
(402) 937-8578
Old 01-30-2012, 06:31 PM
IrvingtonVFD43's Avatar
Send a message via AIM to IrvingtonVFD43
Dunno if you are actually getting Norfolk clear down there in Lincoln. Norfolk on 155.5875, Lincoln on 155.5900, you are probably getting the "bleedover" from Lincoln, since Norfolk and Lincoln are so close together in frequency.
I'm sitting in Columbus and Norfolk is hit or miss in the hotel room I am in.
Remember, unless there is an NSP/NFM/NPPD radio affiliating to the tower, you will not hear anything. Give it time, eventually somebody will pop up.
That bowl of cereal you ate, the ethanol blend gas in your car, even the steel in buildings, I may have played a part in getting it to you! Not I am not a truck driver, but a Locomotive Engineer!
Old 01-30-2012, 11:47 PM
Send a message via ICQ to kfkolb
Dunno if you are actually getting Norfolk clear down there in Lincoln. Norfolk on 155.5875, Lincoln on 155.5900.
According to the RR Database Lincoln is 155.5800 not 155.5900. Is this a typo or is the RR Database wrong?
Old 01-30-2012, 11:54 PM
I got my stuff right from RRDB
Sent from my EVO 3D using Tapatalk
(402) 937-8578
Old 01-31-2012, 08:57 AM
avsfan33's Avatar
Lincoln is 155.580. I hardly hear radio traffic on that site. Troop hq still use low band quite a bit. Used to hear grand island's talk group over the Lincoln tower a lot. Haven't heard it in a while.
Old 01-31-2012, 04:17 PM
Default Hearing
Here in Lincoln with out side ant.on 15 foot mast.
I log cc for Richardson, Polk, Seward, Gage, Madison, Hamilton, Landcaster, Lincoln Counties.
Not much traffic at all.
Today logged G I dispatch, Lincoln dispatch (HQ) Norfolk Dispatch All NSP
Mostly on Seward, and Landcaster towers.
Lincoln HQ troop is still mostly low band.
Old 02-01-2012, 09:10 PM
610 610 is offline
IveringtonVFD I left you pm
