Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Nebraska Radio Discussion Forum
Nebraska Radio Discussion Forum Forum for discussing Radio Information in the State of Nebraska.
Old 01-20-2013, 4:23 PM
Default RACOM EDACS Oakland, IA Site LCN's
Does anyone have the correct LCN's for the Oakland, IA EDACS site? I believe it was call the "Hancock" site at one time. I know this is out of state, but I have a better change of getting it answered here. The database is not correct and was merely added in hopes of getting a correct LCN order.
Thanks,
Tim
Old 01-21-2013, 1:53 AM
AD9O's Avatar
Send a message via AIM to AD9O Send a message via MSN to AD9O Send a message via Yahoo to AD9O
Tim,
Take a look at the RACOM page on the RR Wiki (http://wiki.radioreference.com/index...MN,_NE,_SD,_IA). The section on the system confifiguration shows the different site plans in use.
According to the db, Oakland's site site ID is 7 (the last two digits of the site number), which means plan Q. You should be able to match the in-use frequencies at your site with the LCNs in the site plan.
I hope that helps. Please don't hesitate to let me know if I can assist further.
Tony
Old 01-21-2013, 12:35 PM
Originally Posted by AD9O View Post
Tim,
Take a look at the RACOM page on the RR Wiki (RACOM - IL, WI, MN, NE, SD, IA - The RadioReference Wiki). The section on the system confifiguration shows the different site plans in use.
Tony
Tony,
The DB is wrong. It lists it as a system Q, but the FCC license doesn't match the system Q frequencies. That is why I was inquiring as to what the correct LCN order is. The frequencies listed on the FCC license are probably right. There are a couple odd balls "systems" on the RACOM network and this could be one of them.
Tim
