I Belive Tahoe-douglas And East Fork Fpd Are Dispatched By Douglas
County In Minden. Ill Answer My Own Question 155.055 Is Tdfpd Tac And
155.715 Mhz I Dont Know Also 154.040 Mhz Was Used A Long Time Ago As
A Tac For East Fork Fpd Shannon Reno Nv.
In Reno I Can Receive 155.085 Mhz East Fork Fire Dispatch And 153.800 Mhz
Alpine County Sheriff. I Used To Get 154.400 Mhz Placer County Fire +
154.740 Mhz Douglas County Sheriff (weak) Shannon
What Are The Frequencies For Douglas County Sheriff Channels 2,3 And 4 ?
159.0375 Mhz Is A Interop Repeater On East Peak-shannon
Try 159.600 Mhz Pl 136.5 Eldorado So Eastern Primary (genoa Peak)
Also Licenced Is 155.910 Mhz In The Wellington Area I Can Receive 153.800 And
155.085 Clear In Southwest Reno Also 460.150 Mhz With A Pl Of 100.0 Listed As
State I Heard It As A Bus/transit Company Shannon
159.0375 is the input freq to 156.2250 Douglas County SAR CH-01 PL tone's are 141.3 HZ input & output.
155.1600 is now SAR CH-02 Simplex CSQ, (SAR Member's Confirmed this CH info 02/15/09)
155.1300 repeater output tone 100.0 HZ, 155.8500 input freq, tone 114.8 HZ is active.
155.1300 simplex ,tone 167.9 HZ is now Douglas County Main Jail Control Minden.
And just became active is 151.4525 output,tone 127.3 HZ input freq is 155.6550 tone 141.3 HZ.
And also active 159.2475 output,tone 067.0 Hz input freq is 155.6550 tone 141.3 HZ.
they xmit in simulcast unkown use. Only 151.4525 & 155.6550 show license info ,FCC Database.
155.6550 was being used for the Jail then they changed that and have used it for SWAT/SET Team's
simplex PL 100.0 HZ.
Iam sure there is more to follow,does this info help out? Bill
What Are The Frequencys And Pls For Douglas County Fire Commands 1-3 ?
And Who Uses 154.040 Mhz In The Minden Area ? Shannon
WPYL312 E.F.F. & P.D.
Command CH-01 155.0850 Simplex Pl 100.0
Command Ch-02 155.0850 Repeater Output,155.7750 Input Pl 100.0
Command/Tac Ch-03 154.2800 White Fire CH-01 CSQ
As Far As I Know Their Are 9 Channel's For East Fork Fire & Paramedic District
Never Have Heard Anything On 154.0400 And Ive Been Searching Band's Down Here For Several Year's.
gvranchosbill
