EDACS Standard/Wide
Program all tower sites (or at least those you want) as "sites"
Program all freqs for each site in LCN order
I get irritating noise off the Caliente tower so I deleted it
Your scanner will probably scan faster/more efficiently if you divide the state into geographic areas and make each area a separarte "system", and only scan the system that's of interest at the time
I divided it up into thirds according to NHP Command Areas, more or less, and put just LV talk groups with the Southern Command, Reno talk groups with tower sites in the Northern Command area, etc. You could also do it by county if you were only interested in, or travelling through, certain counties, once you figure out the geographic location of the tower sites.
