radact
Sent out by the head of Metro's Communications Bureau.
Let's mark these dates on the calendar and see what happens. As was mentioned in one of the other posts here, we'll see if Harris gives the "GO AHEAD" on said dates.
Wouldn't it be better to do the switch over on Grave Shift where there isn't much traffic just in case something happens. Someone's not thinking (do they ever?)
We are ready to turn off the connection between the old and the new radio system. The schedule and impact for this is as follows.
· Monday March 28, 2011 @ 12:00 noon – Turn off patches connecting the area commands on the old and new systems. Turn on area command channel connection to the Network First Switch
o Impact – All agencies with authorization to use our “INFO” channel must use only the info channel. Dispatch will not hear them on an area command channel.
o Impact - Media and public will continue to hear the area command traffic via our Network First switch.
· Tuesday July 5, 2011@ 12 Noon – Network First connection will be turned off.
o Impact - No one will be able to hear metro channels unless using a Desert Sky radio with exception of info channel.
o Impact – Media will no longer be able to hear our area command channels unless they have purchased a radio, had it programmed by us, and signed the attached agreement. This agreement may change slightly once reviewed by legal.
We are sending letters and/or e-mails this week to all the agencies we have identified as having agreements with the LVMPD.
