700 Mhz Open-Sky?
Using this site:
http://caprad.org/NlectcRm/Plans/Reg... 1-13-09.pdf
I found the only list that confirms who is using those freqs and where transmissions may be located.
Caprad shows Washoe County list of 700 mhz channels and of all the Channels Statewide,
Washoe Co,State of Nevada list is the only County with all (4) Frequencies im hearing.
Given the signal strength i assume the (4) 700 mhz channels are originating from Slide Mtn.
No where else in Washoe Co is there a Repeater Site that is line of site to my house,signals never picket fence or weaken using rubber duck antenna.
Washoe County
General Use Voice 25KHz 017-020 769.112500 799.112500
General Use Voice 25KHz 057-060 769.362500 799.362500
General Use Voice 25KHz 097-100 769.612500 799.612500
General Use Voice 25KHz 137-140 769.862500 799.862500
General Use Voice 25KHz 177-180 770.112500 800.112500
General Use Voice 25KHz 217-220 770.362500 800.362500
General Use Voice 25KHz 257-260 770.612500 800.612500
General Use Voice 25KHz 297-300 770.862500 800.862500
General Use Voice 25KHz 345-348 771.162500 801.162500
General Use Voice 25KHz 389-392 771.437500 801.437500
General Use Voice 25KHz 433-436 771.712500 801.712500
General Use Voice 25KHz 477-480 771.987500 801.987500
General Use Voice 25KHz 553-556 772.462500 802.462500
General Use Voice 25KHz 597-600 772.737500 802.737500
General Use Voice 25KHz 637-640 772.987500 802.987500
General Use Voice 25KHz 677-680 773.237500 803.237500
General Use Voice 25KHz 741-744 773.637500 803.637500
General Use Voice 25KHz 781-784 773.887500 803.887500
General Use Voice 25KHz 825-828 774.162500 804.162500
General Use Voice 25KHz 905-908 774.662500 804.662500
General Use Voice 25KHz 945-948 774.912500 804.912500
WPUC245 State of Nevada---------------FB2------------MO
State License Voice 25KHz 113-116 769.712500 799.712500 [Slide Mtn?][Open-Sky?]
State License Voice 25KHz 185-188 770.162500 800.162500
State License Voice 25KHz 225-228 770.412500 800.412500 [Slide Mtn?][Open-Sky?]
State License Voice 25KHz 305-308 770.912500 800.912500 [Slide Mtn?][Open-Sky?]
State License Voice 25KHz 645-648 773.037500 803.037500 [Slide Mtn?][Open-Sky?]
State License Voice 25KHz 725-728 773.537500 803.537500
State License Voice 25KHz 765-768 773.787500 803.787500
State License Voice 25KHz 805-808 774.037500 804.037500
State License Voice 25KHz 885-888 774.537500 804.537500
If this is correct and for now i believe it is, its a total bummer.
