just listened to the ATIS on 132.400, and they say Las vegas helo control is on 123.820.
**edit**
Also I am not a pilot, but I am very interested in flying. I looked at a flight instruction book that I have and the pictures of the radios either installed in the plane, or the pictures used in the radio communications chapter only show 2 places past the decimal, so 123.825 would not be able to be tuned in on these radios. Many radios have a knob for each digit past the begining 1 (1XX.XX) to make it faster to tune the radio.
here is a quote from the
N4JRI webpage on aircraft communications:
Understand how tactical frequencies are often selected: Three considerations seem to prevail in the selection of tactical frequencies. First is to find numbers that are easy to remember, and the second is to set them up so that frequencies can be changed easily with the least possible manipulation of the radio dial. Third is to have frequencies in use that won't already be in use elsewhere. (Priorities are not necessarily in this order)
Easy to Remember - There are lots of 'cute' numerical patterns. Famous examples include 333.3, 125.125. 252.525, 123.45, 234.5, 242.4, 282.8, 345.67(5), etc. Also there are suggestive patterns such as 300.6 (Thirty Ought-Six), 357.0 (Magnum) and 303.0 which is suggestive of the 30-30 rifle caliber. Zillions of these combinations are possible in the various bands, which makes them even more popular.
Easy to change - Each digit of a manually-input frequency has its own knob on an aircraft radio. Years ago, some A-7Ds in my town were using 36.8, 46.8 and 56.8 for air/air. They had it set up so that they need only turn the 10-MHz knob to change channels. In most cases, though, we're seeing this done with the 1 MHz and 100 kHz knobs. Consider a unit who uses frequencies like 300.025, 300.125, 300.225, up to 301.525 and 301.625. Look again with the 1 MHz and 100 kHz digits in bold: 30
0.025, 30
0.125, 30
0.225, 30
1.525, 30
1.625. What do want to bet that these guys call these freqs, "00", "01", "02", "15" and "16"?
Unlikely to Interfere - For years, aircraft radios were made to tune in 50 kHz increments. That means that frequencies like 121.1, and 121.15 were tunable by all, but that frequencies like 121.125 and 121.175 were not available except in aircraft with newer radios. You'll find that many tactical frequencies are on .25 and .75 increments. Most UHF air traffic control frequencies are still on .00 and .05 increments, so that gives those who use the .25 and .75 increments a lot of clear channels to work with. This doesn't work so well in Europe, but should do very well in the US.
Also not that the last section seems to refer to the 12.5khz spacing being available to only the military, and only to new radios. it seems unlikley that the civilian aviation world would have to go and buy new radios for a newer spacing, especially with all the talk about switching to 8.33 khz spacing in the future...
