Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Nevada Radio Discussion Forum
Nevada Radio Discussion Forum Forum for discussing Radio Information in the State of Nevada.
Old 02-04-2013, 12:45 AM
K9DUO's Avatar
Default Nevada Shared system
Im visiting Las Vegas for the week and programmed my Pro 197 for the Nevada system so I could monitor the highway patrol while Im here. However Im not getting anything. I programmed all the area control channels and set the program for EDACS standard. Im getting a good signal on the S meter, but no trunking indication. Anything I may be doing wrong or some secret to getting their system programmed?
Old 02-04-2013, 1:13 AM
hotshotmike1001's Avatar
Send a message via Skype™ to hotshotmike1001
hello K9DuO the trunking systems here in las vegas are Messed up You need to make sure you tell the
EDACS standard its rebanded for it to work i get best Sig from North las Vegas Site I Cannot get the shared radio system working at all so hopfully that helps you
My Scanners /Radios
ICOM IC-F4S-4 / E5 MKII Daul Band
BCD996XT Tracker IV/Bearcat BCT8/BCD 396XT APCO 25
Old 02-04-2013, 7:06 AM
KF7RAY's Avatar
Make sure you program ALL the frequencies for each site in the order they are listed. EDACS requires all the frequencies unlike some other systems.
Old 02-04-2013, 9:03 AM
3mary2's Avatar
I have found the Rio Hotel frequencies to give the best enjoyment for the strip area. You are only loading one site into each bank/folder and using all the frequencies as they are listed in the database? I listen to the Rio site from my home in the northwest part of the valley to work at Russell Rd and I-15.
Old 02-04-2013, 9:35 AM
K9DUO's Avatar
Havent done this. I dont have any EDACS systems back home (thank goodness) so Im probably not programming it right. I know its different then Motorola systems. Can you give me some more details?
Also Im using Win500 to program a Radio Shack Pro107
thanks
Old 02-04-2013, 12:09 PM
3mary2's Avatar
Using the Win500 program, go to the database and download the Rio site only. The frequencies have already been changed to show the re-banding. Talk groups to use should be LV-1,2,3, with Tacs and Car to Car 1,2,3. This should automatically set the system up for you. Hope this helps you.
Old 02-04-2013, 1:33 PM
K9DUO's Avatar
I have to manually enter them as im not a premium subscriber....do the freqs have to be entered in numerical order from lowest to highest or in the order they are listed here on Radio References database?
Old 02-04-2013, 3:51 PM
3mary2's Avatar
The way the database has them listed.
Old 02-04-2013, 5:20 PM
K9DUO's Avatar
Thanks a bunch
