MotoTRBO Las Vegas
dtscho
Fredericksburg, VA
These are from my last trip to Las Vegas, which was in 2009:
461.4000 [ ] M Resort - Security (MOTOTRBO - Color Code 1, Slot 1, Group 1) (R)
461.4000 [ ] M Resort - Security (Channel 3) (MOTOTRBO - Color Code 1, Slot 2, Group 1) (R)
463.9000 [ ] Town Square - Operations (Engineering) (MOTOTRBO - Color Code 1, Slot 1, Group 1) (R)
463.9000 [ ] Town Square - Housekeeping (MOTOTRBO - Color Code 1, Slot 2, Group 1) (R)
464.0000 [ ] Town Square - Security (Channel 1) (MOTOTRBO - Color Code 1, Slot 1, Group 1) (R)
I believe there is much more out there now.
Dave
Dick33
Right behind you !!
Town Square changed their codes lately I am too far away to decode them as of now, but Fremont Street Experience below is busy also there is allot of Amateur radio stuff also..
FSE Security 464.1000 RX
Color Code 7
Slot 1
Group 103
FSE Maintenance 452.4250 RX
Color Code 7
Slot 2
Group 102
FSE Show Control 452.4250 RX
Color Code 7
Slot 1
Group 101
joen7xxx
DN-41
There are also several Amateur MotoTurbo systems there. Sorry, I don't have the frequencies handy.
Z0_RICK
I think if you google DMR 6 and DMR or DMARC you will get alot of info on Amateur MotoTrbo.
There is a machine on the D downtown and 1 on Angels. Actually NX7R has one on Black Mtn as well.
Dick33
Right behind you !!
Trump hotel is "Capacity Plus" a trunked Trbo sytem. Hard to decode and listen to unless you have eveything and all in order programed correctly into a radio.
KB7MIB
Peoria, AZ.
Wirelessly posted (Opera/9.80 (BREW; Opera Mini/6.0.3/27.2338; U; en) Presto/2.8.119 320X240 LG VN530)
Just curious, wasn't FSE on the school district trunked system, or something like that, a few years ago? When did they go Mototrbo?
Dick33
Right behind you !!
Fremont Street Experience was UHF conventional they just swapped over to Trbo in the past few months. School district has been on the SNACC system 800 mhz which No private companies are on it.
737mech
Clark County, NV.
So those guys that I hear CSN Security are County employees not a private security company?
Dick33
Right behind you !!
CSN employees work for the state of Nevada, SNACC cannot have for profit entities on the system. CSN was on the NSRS before and moved to expand their operations.
737mech
Clark County, NV.
More MotoTrbo
There's alot more of these systems up in Vegas. Here's a few I found but I did not listen long enough to figure out who so bare with me. 460.725 United Airlines CSA, 462.3125 ?Convention Ctr?, 451.3 ? Level 4?, 452.75 Security something? (Address assignments etc.), one interesting one...413.7625 garbled voice but certainly a DMR system. Also found the USPS on 406.9375.
Hooligan
Clark County, Nevada
Based on seeing their radios a few hours ago, looks like Miracle Mile shopping center went to TRBO. Also, using the data from the RRDB, I'm not hearing the Hard Rock despite looking down on them out the window from maybe a mile away, so perhaps they've also go to the dark side....
I wonder what's causing place to make the jump to TRBO, assuming they're migrating from what's already a narrowband system -- is COMSEC a factor, or is it more along the lines of just a good salesperson & good bandwidth...
(@ the Elara with the SE Michigan Scanner-Geek Crew)
diskmonger
Michigan
Miracle Mile Mall is now on a TRBO Capacity Plus system:
451.500
451.975
460.900
461.150
461.100
Color Code 12
TG 11 - Security Control
TG 13 - Valet
TG 18 - Housekeeping
TG 19 - Engineering
Probably more talkgroups but these are the most active.
