Solicitation is found on fbo.gov
F3GH3B3219AC01-InteroperabilityGateway
They are also looking for some Harris training, but I didn't copy that part.
Interoperability Gateway Characteristics:
Support interfaces from a P25 digital network to conventional radios, consoles, or desksets
Support IMBE encoding for P25 connectivity
Support 128-bit and 256-bit AES encryption
Support redundant power supplies
Support up to 12 interfaced analog devices in a single chassis
Be configurable via software controlled operational parameters via IP network interface
Allow provisioning of each interfaced channel to be associated with a trunked talk group
Support the following conventional analog device interface and controls:
o Full duplex 600 ohm 4-wire audio input/output
o Voice Activated (VOX) energy-detect keying
o E&M Auxiliary inputs/outputs for discrete control
o Coded Tone Continuous Squelch Signaling (CTCSS) encode and Decode capability
o Tone Remote Control (TRC) Encode and Decode capability
o MDC-1200 Signaling Encode and Decode capability
Must be compatible with and integrate onto a VIDA LMR network
6 VIP Dispatch Console Characteristics
Must support the following functions:
Selected and unselected talkgroup monitoring for four (4) talkgroup channels minimum
Independent volume and mute controls for each monitored talkgroup
Group and selective/individual calling display
Caller alias display
Emergency status (Must be able to initiate and clear emergencies)
Clear and create Patches and Simulselects
Instantly replay calls in the Call History display via the built-in call check recorder
Must support 256 bit AES encryption and P25 Over-The-Air Rekeying
Must support network based rekeying from the Key Management Facility directly through the LMR network
Must support the use of headsets as the input/output device
Must support cross-muting of other consoles on the LMR network.
Must be compatible with and integrate onto a VIDA LMR network without any additional hardware/software
Call Director for 9 C3 Maestro Consoles:
Must support telephone interface connectivity to Harris PR9D P25IP LMR system via Harris C3 Maestro Consoles software configuration
