Originally Posted by tbone9597
The Pro 96 is very sensitive when programming trunked systems. Nashua uses a trunked system so when you program the control channels into the scanner in what ever bank you need to skip channel 00and use channel 01. Say you are going to use bank 1 so you would start with bank 1 channel 01 and program the control channels in the order they are on RR. I hope this helps you out and keep scanning NH, Live free or Die!
That information would only apply if it were an EDACS trunk system, which Nashua is NOT. Programming the control channel in the first, 2nd, 30th, or 50th slot within the bank should make no difference.
I also responded to your inquiry in the Massachusetts forum.
