When programming the frequencies, did you start with Channel #01 in the bank (I.e. 001, 101, 201, etc)? If you start at #00, it doesn't take. Also the frequencies need to be in the correct order (Logical Channel Order or something labeled similar).
What I had done w/my Manchester Bank was put the Fire Department's "Tac-16" which is a conventional frequency (866.0125/156.7) in Channel 000 and then started w/the trunked frequencies at 001, 002, etc.
Hope that helps,
John Marcel
K1FDD/WPXA902
Concord, NH Fire Dispatch
Southwestern NH Dist Fire M/A
