Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > New Hampshire Radio Discussion Forum
New Hampshire Radio Discussion Forum Forum for discussing Radio Information in the State of New Hampshire.
Old 02-13-2009, 07:35 AM
Default Nashua Rebanding Roll Call
Could we get reports from people who have their scanners fully operational on the rebanded Nashua system. Be specific with Make, Model, Firmware, Software, any special hints, problems you encountered, etc.
Also reports from those who still need help. Again, be specific with Make, Model, Firmware, Software, etc. and exact problems you are experencing.
Maybe we can match up those who have with those who haven't.
Thanks,
Manny
wb2bon
Old 02-13-2009, 10:57 AM
firenutts's Avatar
Default 396 & 296
this worked for my 396 but not for my 296
I changed my nashua system to a Motorola Custom system with the new frequencies, used the band plans below.
bandplan
1- 851.0125 - 854.0 offset 0 spacing 25KHz
2- 851.025 - 854.0 offset 440 spacing 25KHZ
The 296 picks up a couple of the DPW talkgroups and it locks up on it. I doesnot pick up the fire/ems/police groups. If anyone has info for the 296 I would appreciate it.
Old 02-13-2009, 08:36 PM
Default BC296 link info
Uniden Links:
ScannerManuals < UnidenMan4 < TWiki
BC296DFirmwareUpdate < UnidenMan4 < TWiki
Also, the tables you listed don't appear to be correct. This should work, per link above.
Band Plan Base Freq (Lower) Base Freq (Upper) Offset Polarity Spacing
1 851.0250MHz 854.0000MHz 440 + 25 kHz
2 851.0125MHz 868.9875MHz 0 + 25 kHz
My Scanner:
Scanner: Uniden BC796D
Firmware: 3.60
Software: Uniden's included / Proscan 1.8.3 - Neither handles rebanding.
Control channel: 853.2625 mHz.
Instructions: BC796DFirmwareUpdate < UnidenMan4 < TWiki
Some postings have differing trunking tables. The ones in the above link is correct.
Entered tables manually. The old software was used for the talk-groups and frequencies.
Some growing pains, but appears working ok.
Manny
wb2bon
Old 02-14-2009, 12:20 AM
Iam running the new rebanded system fine uniden bc396t here with all current firmware installed.
Old 02-14-2009, 12:47 PM
NYRHKY94's Avatar
Successfully Rebanded the Following Scanners for Nashua:
1) Pro-96 & Pro-2096
v1.4 Firmware
Installed Win96 v1.59
Went to Nashua Bank in my P96 File
Selected multi-table under MOT 3600 CC
Clicked on Extended Tables Button
Selected 800 MHZ Rebanded
Saved & Uploaded the P96 File
2) Uniden BCD996T
v3.0.2 Update
Hand configured the 2 Custom Band Plans noted on the bottom of
Uniden's instructions for the v3.0.2 update
3) PSR-600
v1.6 Firmware
Installed Win500 v1.80
Went to Nashua system in my Win500 File
Selected custom under the trunking tables drop down menu
Put rebanded control channels in system frequencies tab
Clicked on trunking tables button and selected 800 MHZ rebanded
Saved & Uploaded the Win500 File
4) Pro-106
v1.6 Firmware
Thanks - Mike
Thanks - Mike
PSR-600, Pro-106, Pro-2096, Pro-96, Pro-2053, Pro-2052, BCD996T, BC796D, BC898T, BC370CRS, BC210XLT
Listen to my feeds at:
Radio Reference NH
Radio Reference NJ
Old 02-14-2009, 12:55 PM
Default Bc796d
Firmware: 3.60
Instructions:
http://info.uniden.com/twiki/bin/vie...FirmwareUpdate
Some postings have incorrect trunking tables. See message 396 & 296 above.
The ones in the above link are correct. Entered tables manually.
Manny
wb2bon
Old 02-14-2009, 08:24 PM
n1das's Avatar
Exclamation
Control channel is 853.2625 MHz
853.2625 mHz = 0.8532625 Hz
David Sterrett
Nashua, NH
Ham [HA] = N1DAS (2/1984)
GMRS [ZA] = KAE9013 (12/1992)
Old 02-14-2009, 09:10 PM
northzone's Avatar
What?? 853.2625mhz = 853262500.0 Hz
Old 02-14-2009, 09:21 PM
Default Dave, K1DAS is correct
Sorry for the typo.
"mHz" is a Millihertz, or a thousandth of a hertz (sure wish we has cycles back).
"MHz" is a Megahertz, or a million hertz.
Manny
wb2bon
Old 02-14-2009, 10:41 PM
n1das's Avatar
Cool
m = milli = 0.001
M = Mega, i.e., million = 1,000,000
1 mHz = 1 milliHertz = 0.001 Hz
1 MHz = 1 MegaHertz = 1,000,000 Hz
I've rebanding my RadioShack PRO-96 successfully using Win96.
I need to get a new cable to work on my Uniden 396T.
David Sterrett
Nashua, NH
Old 02-15-2009, 12:00 AM
Sinister's Avatar
Moderator
Send a message via AIM to Sinister
Rebanded Nashua with success using Win500
Pro-197
v1.6 Firmware
software Win500 v1.80
Put Nashua rebanded frequencies in Win500 by selecting system frequencies tab
Thanks Glenn
RR Moderator
Digital Scanner Comparison Chart
NH Wiki
Similar Threads
NC Roll Call KE4ZNR North Carolina Radio Discussion Forum 116 11-12-2009 03:42 PM
Illinois Roll Call [NEW 2009, Please call in again!] Starcom21 Illinois Radio Discussion Forum 50 11-06-2009 06:58 AM
Racom System Roll Call Dak48 Iowa Radio Discussion Forum 2 01-24-2009 07:37 AM
Emergency Responder Roll Call gldavis Utah Radio Discussion Forum 2 07-25-2008 09:41 PM
Sac Sheriff Roll Call scannerboy02 California Radio Discussion Forum 8 11-18-2007 02:47 PM
