Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > New Hampshire Radio Discussion Forum
New Hampshire Radio Discussion Forum Forum for discussing Radio Information in the State of New Hampshire.
Old 03-20-2009, 08:26 AM
Default Is It Possible To Receive Frequencies From The Entire State?
I am new to listening to the scanner. I am trying to receive frequencies from all over the entire state, anyone know if that is even possible without putting up a skyscraper for an antenna?
Thanks!!
Old 03-20-2009, 05:56 PM
Sinister's Avatar
Moderator
Send a message via AIM to Sinister
Your analogy would be correct about the skyscraper. What type of antenna are you currently using?
Thanks Glenn
RR Moderator
Digital Scanner Comparison Chart
NH Wiki
Old 03-20-2009, 06:28 PM
The topography of NH would limit your reception, unless you are on top of mt washington. Antenna, elevation and receiver are key.
Old 03-21-2009, 06:08 AM
Send a message via AIM to jmarcel66 Send a message via Yahoo to jmarcel66 Send a message via Skype™ to jmarcel66
Short Answer..No. The only three places where it may be conceivable would be Mt Belknap, Mt Kearsarge & Mt Washington in that order. And all have some limitation. Between Topgraphy (as mentioned), the Granite, and varying signal strengths of the various systems, there is likely no where.
John Marcel
K1FDD/WPXA902
Concord, NH Fire Dispatch
Southwestern NH Dist Fire M/A
Old 03-21-2009, 08:38 AM
NYRHKY94's Avatar
Mcwebsitedesign:
Alternatively, you "can" listen to other people's scanners from every county in NH with the exception of one at:
New Hampshire Live Police, Fire, and EMS Scanners
I know it's not what you're really asking for, but I couldn't resist ;-)
Thanks - Mike
PSR-600, Pro-106, Pro-2096, Pro-96, Pro-2053, Pro-2052, BCD996T, BC796D, BC898T, BC370CRS, BC210XLT
Listen to my feeds at:
Radio Reference NH
Radio Reference NJ
Old 03-22-2009, 01:10 PM
Hi,
Thank you for your help. I am currently using a very amature set up that consists of my portable race scanner and a J-Pole I bought on eBay.
Matt
Old 03-22-2009, 01:19 PM
Originally Posted by NYRHKY94 View Post
Mcwebsitedesign:
Well, thanks for that link! That is very cool! Is there any way to listen to multiple feeds at the same time on ScanAmerica? I'm assuming not.
Well, anyone in the listening area of the Southern end of NH (Manchester and South) that listens between 7am and 6pm (approx) on weekdays that would be interested in a business partnership?
Sure would be cool to have an online programmable scanner! That would solve my problem.
Old 03-22-2009, 09:58 PM
NYRHKY94's Avatar
Yes, you can listen to multiple feeds at the same time. You can run multiple instances of the WinAmp player on your PC and have each one broadcast a different feed. The sound from each instance will play over the computer's speakers independant from one another.
P.S. Please note that the more feeds you have running at the same time on 1 PC, the more difficult it is to distinguish between them when the feeds are broadcasting simultaneously.
Thanks - Mike
Radio Reference NH
Radio Reference NJ
Old 03-23-2009, 08:12 AM
ahhh, ok, I will give that a try. Lots of multi-tasking!
Thanks!!
Old 03-29-2009, 10:48 AM
Search for the ProScan client, when you load it you get a list of Proscan servers. Some of them are in Southen NH and show the scanner face so you can identify the transmitting agency. There a couple that monitor Nashua and Manchester along with surrounding areas.
Old 03-30-2009, 09:21 AM
Excellent! Thanks for the info!
**** If anyone would like to help with reporting NH traffic problems let me know ****
Old 04-03-2009, 08:55 PM
I stream statewide NHSP WITH alpha tags and no ads at scanner
For the select few, I also offer a programmable option where you chose what you want to hear. If you use firefox you need the IE tab plugin.
Regards,
Old 04-03-2009, 09:51 PM
I use ddemers stream often and it's nice. it pretty much covers everything I want to listen too in my area.
John
Old 04-04-2009, 08:34 PM
Send a message via AIM to Deimonte38 Send a message via Yahoo to Deimonte38
any body have a freq for Epping NH PD
Old 04-04-2009, 08:46 PM
Sinister's Avatar
Moderator
In Stratford County it is listed here
Thanks Glenn
RR Moderator
NH Wiki
Old 04-05-2009, 08:52 AM
I believe Epping PD is still dispatched by Rockingham County Sheriff. Don't know if they have a daytime dispatcher.
154.9500 NAC-117 is Rock "A" and should be Epping's Dispatch frequency.
154.8150 NAC-117 is Rock "C" and is Countywide Operations repeater.
John Marcel
K1FDD/WPXA902
Old 04-05-2009, 09:20 PM
You are correct, they are dispatched by Rockingham county, they do not dispatch themselves. The other Rock frequency for the East side is 155.415. They are all P25.
Old 04-05-2009, 10:16 PM
IP 71.168.93.229 who logged on yesterday can you email me.
Regards,
Similar Threads
Any New Talk Groups cajunjerry Louisiana Radio Discussion Forum 8 09-09-2008 10:08 AM
NC State Police Frequencies? rabbitdude22 North Carolina Radio Discussion Forum 8 07-26-2008 09:11 PM
Somerset County - SCI?? csvff78 Pennsylvania Radio Discussion Forum 15 02-09-2008 11:34 PM
New Vermont State Frequencies LathamScan Vermont Radio Discussion Forum 2 02-07-2008 09:54 PM
FL State Park frequencies bravo14 Florida Radio Discussion Forum 5 01-10-2008 12:25 PM
